BRAVE_HELIOS
Apr 22 2017, 10:06 AM
Hey all,
Inching closer to going electric on my V8 conversion car. Right now; going through the process of cleaning out radiator and water passages/block with ThermoCure, then Prestone citric acid flush. Assuming I get a really clean system but not fix the run hot situation; I will go electric. Where is the best place to mount the electric pump? It would seem that the
easiest way to go in my case is with this:
http://www.jegs.com/i/JEGS-Performance-Pro.../50930/10002/-1Click to view attachmentIt a 50 GPM unit that should bolt right up to the Renegade remote water pump housing already in place in my car on the lower left hand side of the engine... that is assuming there is enough clearance between the water pump and the firewall.
Would this work? I have heard stories going back and forth about mounting the pump by the radiator or by the engine.
BRAVE_HELIOS
Apr 22 2017, 11:02 AM
914GT
Apr 22 2017, 12:53 PM
Best location is the lowest point in the cooling system and at the rear (below engine). During acceleration the suction side of the pump will have highest pressure and helps the pump when you need maximum flow.
BRAVE_HELIOS
Apr 22 2017, 01:38 PM
QUOTE(914GT @ Apr 22 2017, 12:53 PM)
So then my idea of using the Jegs pump and mounting it the Renegade remote water pump housing is a good idea (as long as clearance allows)?
BRAVE_HELIOS
Apr 22 2017, 02:13 PM
As a side note... I just took the car for a short drive; still with the Prestone Radiatior Flush and Cleaner running through the cooling system. I'm doing the heavy duty cycle cleaning... 3-6 hours of 'normal' driving. Of course, always with an eye on the temp gauge. Anyway; today after getting back from my short drive, I noticed that the overflow bottle in the trunk was actually bulging quite a bit. There is no pressure cap on it, just a simple snap type cap, yet it was definitely looking like it was under pressure. Temp gauge read around 180 and the electric fan was running.
Is this normal? Sometimes I wonder if I have the expansion tank plumbed correctly. Can you tell by looking at the pictures and descriptions that it is installed correctly?
BRAVE_HELIOS
Apr 22 2017, 03:25 PM
These custom fabricated cars... you sometimes just don't know how to apply standard processes.
Case in point; Along with the Prestone Radiator Flush and Cleaner liquid, I purchased their Flush and Fill Kit, complete with T's, clamps and Back Flow Preventor Coupler. Thing is, how do I install it on my car? Directions say to install T on inlet side of the heater (core) in order to allow back flushing. In my case, my coolant flows as such; I tapped into the inlet hose of the radiator to take coolant to the heater core then tapped into the radiator outlet hose to take the coolant away from the heater core and back to the water pump.
Would I still follow the directions on the Fill and Flush kit to allow back flushing? It would seem to me if water from the garden hose was flowing back towards the engine via the radiator inlet hose, that when the engine was running withe the garden hose also running water, the pump flow/direction and garden hose flow/direction would work against each other. The instructions state to keep the pressure cap off and perhaps that is where the pressures and flows would cancel each other?
Perhaps another approach would be... what is the best way to back flush the system in my car and with this setup?
Mike Bellis
Apr 22 2017, 03:39 PM
I have heard of those electric pumps bottoming out in the housing and binding the impeller. Make sure to check for this. I do think it's your best be/easiest install.
If you are talking about the bottle in the trunk bubbling, that hose should connect to a filler cap vent. Should be no pressure unless your cap has failed.
Andyrew
Apr 22 2017, 04:25 PM
QUOTE(Mike Bellis @ Apr 22 2017, 02:39 PM)
Even the mopar pumps do that. I had to clearance my old rebuilt mopar pump for the impeller.
bulitt
Apr 22 2017, 04:40 PM
Lots of threads on this topic...
BRAVE_HELIOS
Apr 22 2017, 04:44 PM
QUOTE(Andyrew @ Apr 22 2017, 04:25 PM)
I was about to ask... if the Jegs unit is made to install in a stock MOPAR W/P housing and I (we) have stock MOPAR mechanical W/P installed in the Renegade Remote W/P housing, how could they not either be interchangeable (both work correctly) or both have the same potential clearance issues.
How does one check for clearance anyway?
BRAVE_HELIOS
Apr 22 2017, 04:46 PM
QUOTE(bulitt @ Apr 22 2017, 04:40 PM)
Click to view attachmentOh yes; I know and it's still very confusing... perhaps too much info out there.
I am looking for the most up-to-date info y'all have!
914GT
Apr 22 2017, 05:10 PM
An expansion tank and overflow tank are different things. The expansion tank is pressurized and should be the highest point in your system, usually above the thermostat. The radiator cap is on this tank and it opens to purge out trapped air and coolant to the recovery tank.
I use a Dendenbear remote pump and water header like shown in the picture above. I don't know about the pump you are using but it should be probably be bench tested to make sure there's no interference with the impeller. With these electric pumps it's recommended not to use any teflon thread tape and also be careful that excess Permatex or sealants do not get into the impeller that could jam it up.
BRAVE_HELIOS
Apr 22 2017, 05:22 PM
QUOTE(914GT @ Apr 22 2017, 05:10 PM)
My expansion tank (VW Passat unit with pressure cap) is mounted above the T-stat. Pressure cap is new. Please note picture with descriptions as to which ports on the expansion tank go to where. I am pretty sure it is plumbed correctly. Not sure about the 90 degree elbows used for clearance and so rubber hoses will not kink.
Does the Dendenbear unit allow for coolant bypass when cold? Mine is a Renegade kit, therefore it has two separate ports and hoses going to those inlets.
I see... mount the pump in the housing and rotate to check for metal to metal sounds etc...
Andyrew
Apr 22 2017, 05:29 PM
QUOTE(BRAVE_HELIOS @ Apr 22 2017, 03:44 PM)
How does one check for clearance anyway? Check for clearance by installing it and seeing if it spins freely. If its difficult to bolt down tight then there is another sign.
BRAVE_HELIOS
Apr 22 2017, 05:33 PM
QUOTE(Andyrew @ Apr 22 2017, 05:29 PM)
Ok. So the idea of going with the Jegs units that mounts in the Renegade housing sounds viable? I'm sure I can file/grind at least some material off the housing for clearance without it being detrimental to either the housing or the pump; yes?
Andyrew
Apr 22 2017, 05:46 PM
Seems like it was designed to be used as a replacement of the Mopar belt driven pump so yes I think it would make perfect sense in this application.
Scroll down and you can see the issue I had with the rebuilt pump I had.
http://www.914world.com/bbs2/index.php?sho...14780&st=20
BIGKAT_83
Apr 22 2017, 05:47 PM
I hope you have the hose from the header tank going to bottom of the recovery tank. I cant see it in your pictures. If its going to the top as it looks like there is no way for the water to get sucked back into the system.
I have a Meziere 316 55gpm remote pump I could send you to try. I would be a little harder to plump up but might save you from buying something you don't need.
914GT
Apr 22 2017, 05:51 PM
It's not clear to me where the radiator pressure cap is. I guess the Passat tank looks more like a coolant recovery tank to me. None of the remote water pumps, electric or mechanical, are going to have a bypass like the stock pump has. You'd need a pump that mates to the holes on the block, which means modifying the firewall for clearance to the pump. I have an external bypass incorporated into my heater hose connections to give some coolant flow when the thermostat is closed. I found that the bypass keeps the engine cooler because it allows coolant to circulate in the block and heads until the thermostat needs to open up.
BRAVE_HELIOS
Apr 22 2017, 06:10 PM
QUOTE(BIGKAT_83 @ Apr 22 2017, 05:47 PM)
Thanks... I may take you up on the offer. I am so afraid that I will spend the money on an electric unit just to find out it is some other issue. That's why I am now cleaning out the system the best I can (without removing the engine) to see if this makes a difference. I just have had no luck with making this car remain running at a decent temp (like 180-200). I also now know to elevate the front of the car so the petcock located on the top right of the radiator can be used to bleed the system. I use a slightly modified vacuum brake fluid bleeder like this one and it works really well in helping me bleed the system.
Click to view attachmentAs for the Passat header tank (I call expansion/ tank) overflow line, it does connect to the bottom of the recovery (I call overflow) tank. The recovery tank overflow line used to vent to the ground but I now have it going into another smaller bottle located at a lower point in the engine bay by the trunk bulkhead. There may be some sort of blockage there causing the header tank to build pressure. I will check it out.
BRAVE_HELIOS
Apr 22 2017, 06:15 PM
QUOTE(914GT @ Apr 22 2017, 05:51 PM)
Yes, the VW expansion tanks utilize a pressure cap, although they are a bit problematic especially when trying to connect a pressurizing tool like the ones you can rent from your local FLAPS. I had to make an adapter in order to be able to use it.
BRAVE_HELIOS
Apr 22 2017, 06:23 PM
QUOTE(BRAVE_HELIOS @ Apr 22 2017, 06:10 PM)
I may have neglected to mention something because I just installed it and am waiting for the results.In the Bible V8 Conversion Book; there is one small paragraph that mentions KEP recommending the use of a restrictor washer located at the inlet of the radiator. I installed one with a 3/4 inch diameter (the inlet size of the rad is 1.5 inch). Also the T-stat has been gutted so no restriction there.
I have pretty much tried every iteration I can think of... T-stat in, T-stat out, restrictor washer out, restrictor washer in, expansion tank out, expansion tank in. The only thing I have not tried is the electric water pump.
What I do not understand is if the mechanical pumps are not efficient enough to work in this application (V8 914) then why offer them?
914GT
Apr 22 2017, 07:00 PM
I never thought the restrictor washer was necessary. I understand the thinking behind it, such as raise the pressure on the line to the radiator to either prevent steam bubbles or reduce the flow so the radiator has more time to cool. Some of this is based on old fixes going back to the 1950s.
I'd make sure you have all the air out of the radiator and hoses at the front. This means having a bleeder petcock at top of rad you can open when you are filling the system. Also check that you don't have excessive hot air recirculation. With the inner wheelhouse openings there will be some recirculaton to the front of the radiator. I'm assuming you already have good shrouding around the radiator. One way to check recirculaton is to measure the inlet temp with the engine idling and fans running, and hood closed. Then open the hood and see how much of a temp drop you have, with the radiator heat allowed to exit up where it really wants to go. If this is more then 10 degrees then you might want to look at how the air is recirculating and block it with a spoiler or air dam under the car.
If you have a new radiator why are you doing a flush? Do you think the block has a lot of rust in it? If it does that can clog up a new radiator pretty fast. Check the water you flush out to see if it has a lot of rust particles in it.
Good luck with this. Hope you find the problem.
BRAVE_HELIOS
Apr 22 2017, 07:19 PM
QUOTE(914GT @ Apr 22 2017, 07:00 PM)
I am thinking the block had crud in it. When I would use new coolant, it would quickly become dark like it had been in there for a long time. I placed pieces of nylon stockings at the inlet of the rad to help capture as much crud as possible and have removed the rad and did a flush/back flush via a garden hose... flows nicely. Question, can a rad still be clogged if water from a garden hose flows through?
I had the bumper inlet well shrouded and sealed. So much so that when the fan is on, I can place a license plate on the bumper grill opening and the suction of the fan will hold the license plate firmly in place! I am trying to understand what you say about the temp delta. I will read it again!
dyckster
Apr 22 2017, 10:04 PM
if you want to see how efficient your rad/air inlet system is, you could easily pinch off your heater hoses, then plumb in two different water temp gauges. This will tell you what your water temp is going in and out of the rad. And if it is cooler hooked up that way, maybe look at your heater core plumbing.
What I really like about the electric pump is the ability to circulate and purge air without overheating on the highway. And I think trapped air is a big issue.
With my belt driven pump, ill fill it up with coolant, go for a drive, it needs more, next drive needs more, it took a lot of driving to get it full.
BRAVE_HELIOS
Apr 24 2017, 11:42 AM
If I understand this correctly; where would I measure the inlet temp with the fans running and the hood closed? Would I measure it on the outside of the car by the bumper intake grill? Then remeasure the temp with the hood open?
914GT
Apr 24 2017, 02:36 PM
If you can measure the air temp in front of the radiator you can get some idea of how much hot air is being recirculated from the wheelwells at idle and when the car is not moving. There will always be some amount hot air get pulled back into the front depending on how you made your radiator inlet openings. If all your air is through the front with the front bumper cut out, it should be less of an issue then if you have openings in forward part of the trunk floor. If enough air recirculates it can cause your engine temperatures to creep up when the car is not moving, and you can never get the temp to stabilize. There can be other cooling system problems that can cause this to happen also.
So if you can monitor the air temp in front of the radiator, then open the hood and see if the temp drops quickly (close to ambient) that's a good sign that there's some recirculation going on. If there's not much drop, just a few degrees, then you don't have a problem. Since hot air rises the radiator heat is going to escape upward quickly with the hood open. With the hood closed it is forced out around the front wheels and it has to find its way out around the fenders. There's more turbulence going on and some of it can get sucked back into the radiator depending on the layout. So this is just a quick check to either see if this is a concern or rule it out as a non-issue.
jmmotorsports
Apr 24 2017, 07:19 PM
i am useing a 55gph mexaire pumpin my ls1 car they recomended mounting it close to the radiator and below the radiatir centerline55 GPH mezaire pump can't spell
cali914
Apr 25 2017, 08:27 AM
I had a small block 427 in my v8 Porsche and had the Ron Davis radiator I mounted the pump in the front compartment on low side of radiator inlet. It said stand it straight up but I kept inlet and outlet parallel to floor and had 0 problems. I was using Meizere 55gpm remote water pump. Very excellent quality part. Expensive though. What I don't understand is I have a honda v6 engine now and using the stock Honda water pump and it works fine I think it's more about line size and radiator that affects about 80 percent of the cooling in these cars
BRAVE_HELIOS
Apr 25 2017, 08:41 AM
QUOTE(cali914 @ Apr 25 2017, 08:27 AM)
Well, here we go! Shall we take a survey as to best place to mount a pump... by the rad or by the engine? Highest nods to either wins!
My rad hose lines are not what is recommended by Renegade.
Radiator: 1.5 inch inlet and 1.75 inch outlet diameters
Renegade W/P housing: 1.25 inch diameter
T-stat outlet: 1 inch diameter
And 1.5 inch diameter hoses going to and fro with appropriate size down/size up adapters.
Could this be the culprit? So far, the restrictor washer located at the rad inlet (3/4 inch diameter) does not seem to be hurting things. I do need to take it for a good drive now that is has clean/clear water running though it.
Andyrew
Apr 25 2017, 10:06 AM
Best place is by the engine feeding the inlet to the engine. The cold water will allow for longer pump life.
I run 1 1/4" lines front to back.
Again, I have much less displacement now, but thats what I did with the v8 as well.
914GT
Apr 25 2017, 10:42 AM
I've used 3/4" I.D. steel pipe under the car for coolant lines and never had overheating problems, and that's here in southern Arizona on a car with A/C. I've also used 1" I.D. steel tubing and it made no difference. If you have larger rubber hose then I don't think that's your problem.
I think having an electric water pump on the radiator outlet makes for an easier install, and is easier to access, but remember again that during hard acceleration the coolant is moving away from the suction side of the pump and not toward it as when it's at the engine. For a street car it's probably not a big deal, but on the drag cars that can experience a few Gs that would be a different story.
I assume that you open that top radiator petcock when you fill your system and keep it open until no more air bubbles come out. I have a short length of clear vinyl tubing on mine that runs to the bottom of the car, then I keep an eye on it closing it only until there's no more bubbles. Otherwise if there's a pocket of air in the top of the radiator it will not get purged out under normal operation, and it decreases the cooling capacity of the radiator and system pressure.
You might also try to disconnect the heater core to see what effect it is having unless you have a valve on the line controlled by your dash heater lever. With it connected as it is now in the front it will bypass the radiator. On a stock SBC the heater supply line comes off the top of the intake manifold before the thermostat then returns into the suction side of the water pump. This circulates hot coolant in a separate loop then that flow going to the radiator. If you keep the heater core across the radiator you may need a restrictor in the line so it's not bypassing too much around the radiator.
BRAVE_HELIOS
Apr 25 2017, 11:22 AM
QUOTE(914GT @ Apr 25 2017, 10:42 AM)
Preferred on the radiator outlet... and close to the radiator?
When you leave the petcock open on the top side of the rad when filling the system; do you also elevate the front of the vehicle so that without a doubt; the petcock sits higher than the t-stat/top of the engine? My radiator does not sit straight up... the top is angled towards the front of the car and as in close horizontal level with the t-stat.
The addition of the heater core and lines is a relatively new thing... the run hot situation has been with me since day one. There is a shut off valve on the inlet side of the heater core (close to the bulkhead and heater core itself). I have tried filling the system with the valve opened and closed without too much difference.
914GT
Apr 25 2017, 11:59 AM
For water pump location I prefer below the engine for the reasons stated previously.
I don't think raising the front of the car will help much if there are hoses or any part of the system (in front trunk area) that may be higher then the petcock. The main thing though is to ensure the radiator is full of coolant. Raising the front will not allow any trapped air at top of the engine to escape - that has to be bled out by your expansion tank.
Can you connect into your system somewhere, such as at heater hose fitting, and try to pressurize the system with compressed air and get it to hold at 16 psi or whatever cap pressure rating you have? The system should hold pressure up to the point that the cap opens and pushes coolant into your overflow tank.
BRAVE_HELIOS
Apr 25 2017, 12:30 PM
QUOTE(914GT @ Apr 25 2017, 11:59 AM)
Earlier in this thread, I asked about the best place to install a Prestone Flush and Fill ‘T’ to back flush my ‘special’ system. The instructions say anywhere on the inlet heater hose side of the heater core. Since my inlet to the heater core comes from the inlet to the radiator… I just did not know where to tap. So I took a WAG and decided to place the ’T’ on the heater core inlet hose, between the radiator inlet and the heater core inlet. I followed the rest of the instructions and ran the garden hose while the engine was running for around 10 minutes. The temp gauge never got past 150 (temp sensor for gauge located on intake manifold, by t-stat) and eventually all the water coming out of the open expansion tank, ran clear.
I suppose that would be a good spot to try and air pressurize the system; correct?
914GT
Apr 25 2017, 12:48 PM
Personally I don't use back flush kits as they introduce another potential failure point in the system. If I suspect a radiator problem I disconnect the hoses and flush water through it opposite the normal direction of flow, then look to see if anything comes out. Same with an engine block removing the drain plugs. I think the flush kits leave tap water in the system and I like to start off with new antifreeze and distilled water.
For pressure testing I think anywhere you can tie into the pressurized part of the system will work as long as your expansion tank and pressure cap are connected as normal.
BRAVE_HELIOS
Apr 25 2017, 01:01 PM
QUOTE(914GT @ Apr 25 2017, 12:48 PM)
That should work. The VW cap is rated for around 20 psi; I think. I can pressurize the system while the cap is on and wait for the cap to open and allow the coolant to flow to the overflow tank.
3liter914-6
Apr 25 2017, 04:51 PM
Just a couple of things.
Electric pumps flow
less coolant than a mechanical water pump at nearly everything above idle, if you're having a cooling issue installing an electric pump is going backwards. The reasons to install an electric pump are if you need to remotely mount a water pump or you're trying to get the absolute most horsepower you can out of an engine. If you think the water pump is the issue, get a Stewart high flow water pump and be done with it knowing you've got the best on there and it's not a WP issue.
More flow=more cooling, it's physics. You don't want to slow down your flow, a restriction will only cause problems, not help them.
If you're having problems, I'd first make sure what I had is working correctly. It sounds like you're having issues, or at least worried about bleeding the system. When I was building my V8 Volvo, I had similar issues which took out a headgasket before I bought an Airview coolant refill kit, and eventually ditched my convoluted setup. It uses shop air to create a vacuum and then sucks the coolant back in leaving it perfectly filled without air voids. Looks like there are cheaper ones out there like
this. Yeah, it's a bit of money, but it's worth it -- it makes my life so much easier on dozens of cars (but not my bugs or 914).
I don't know the history of your engine, but if you're sure that you don't have any mechanical issues (such as head gasket, or timing) that could cause it to run hot, I'd reconsider the size of my radiator and the airflow through it.
BRAVE_HELIOS
Apr 25 2017, 05:08 PM
QUOTE(3liter914-6 @ Apr 25 2017, 04:51 PM)
Electric pumps flow
I've wondered about timing, quite a bit especially now. With the v8, it is almost impossible to check the timing to make sure it is correct. Time it by ear... if it starts pinging under load, back it off until it stops. Could it still affect engine temps? Possibly or probably.
I do not believe there is anything wrong with the engine itself other than it tends to run rich. No white or blue smoke out of the exhaust. No oil in the coolant or coolant in the oil.
I am waiting for the weather to get better and I'll take it for a good drive as it sits now (fresh clear water, system bled and with the restrictor) to see how it goes. I will also look into the Airview system.
914GT
Apr 25 2017, 06:02 PM
You can check timing by relocating the timing mark/scale so it's visible from underneath the car on the driver side. I relocate the TDC mark on the balancer and just shoot the timing light up from under the car to set the initial advance. I've got photos of this if you're interested.
BRAVE_HELIOS
Apr 25 2017, 07:21 PM
QUOTE(914GT @ Apr 25 2017, 06:02 PM)
That might not be a bad idea. Like I have said, I have wondered how far off my timing is. I don't think it is too far off... no discernible pinging under load; but if it being only slightly off can affect running temperatures, then it's definitely worth checking out. Pictures and descriptions please!
914GT
Apr 25 2017, 08:10 PM
Here's the timing mark setup on my engine. The orange mark on the balancer is at TDC and 0 degrees on the timing pointer. It would be nice to have it lower but I can still easily see it from under the car.
BRAVE_HELIOS
Apr 26 2017, 08:23 AM
Electric pumps flow
I looked at the Airview system:
https://www.ecstuning.com/b-schwaben-parts/...ol/003466sch01/Wouldn't my vacuum brake bleed tool work the same? When connected; it uses vacuum from a compressor to draw out coolant from the radiator petcock and as long as I keep the overflow bottle full; I can continue bleeding the system like this until (I feel?) the system has been successfully bled.
BRAVE_HELIOS
Apr 26 2017, 08:55 AM
QUOTE(914GT @ Apr 25 2017, 08:10 PM)
Awesome! But it looks like the engine has to come out in order for me to do this... that's a lot of work :-)!
914GT
Apr 26 2017, 10:06 AM
Right, one of those things that would be done with the engine out. If you need to drop the engine to take care of other issues then adding a relocated timing mark would be something to add to the list.
burton73
Apr 26 2017, 11:45 AM
Just wondering. The picture of your SBC with a Dedenbear WH-1 got me curious.
I went to their site and saw that they had Electric water pumps set to flow 23 GPM.
The other pumps that where covered in posting pumped much more that that. Question is a slower GPM flow better for cooling. I think it has been posted many years ago but I cannot remember. Also where do you get a Vibration Dampener for a HP SBC with a V belt grove? I have a very old one from GM in the 60s.
Bob B
914GT
Apr 26 2017, 01:00 PM
The Dedenbear remote pump on my conversion has performed very well for the past 15 years so I don't feel that GPM numbers are extremely critical. Obviously you need enough coolant flow to prevent excessive coolant temperatures where it exits the engine and hot spots inside the engine. But that's also going to be dependent on the engine inlet temperature (and radiator performance). The more important factors are going to be radiator size and efficiency, and controlled air flow through the radiator. The pump is moving the heat from the engine to the radiator, the actual heat exchange is from the radiator to the air. That is where more flow is better (air flow) and not really the coolant flow rate from engine to radiator. There are a lot of arguments over this, not just in the 914 conversion world, and that's fine. But I know the setup I have works well for me.
Another thing that needs to be considered is that even though a pump can flow a maximum GPM under ideal or no-load conditions it won't necessarily be able to flow that rate in an real closed cooling system. The engine block, heads, thermostat, pipes/hoses and radiator will all restrict flow and trying to force a higher GPM through the system can result in excessive pressures or turbulence. It would be nice to know if there's an optimum GPM for a system but that's probably unique for every situation. If you had a flow meter with temperature & pressure gauges you could probably get some numbers to take some of the mystery out of this.
On the V-groove balancer that is a GM part, p/n 3896590. As far as I know it's still available from GM and other sources online.
dwillouby
Apr 27 2017, 06:33 AM
Glad I saw this! I am going to order this pump as I currently have the Renagade setup.
Mine seems to cool fine but the engine heat soaks when shut down. I want the use the electric pump to run after the engine stops and circulate till temps come down.
I was going to try the Davies Craig pump but have to rework things. I will sell this pump(new in box) to buy the other.
David
BIGKAT_83
Apr 27 2017, 06:46 AM
QUOTE(dwillouby @ Apr 27 2017, 08:33 AM)
David
This will answer a few questions about which cools better belt driven or electric. Interested to see if you see any difference in the cooling when running. I'm thinking of going with a electric pump just to free up space to mount a ac compressor.
Bob
burton73
Apr 27 2017, 10:50 AM
Thanks for the lead on Davies Craig pump I looked them up on the web.
It sure looks trick. Davies Craig DC-8870
The EWP 130 is made of aluminum with AN fittings. Not sure what model would work best for SBC and 914 layouts but I guess this is it. $465. For the kit with controller. Another $114. For the SBC set up on the engine. Davies Craig DC-0444 - Davies Craig Digital Thermatic Fan Switch Kits . $77. More
Not sure if that is it but the full boat is looks like it would be like it is $656. Not cheap but if it works perfect?
Bob B
dwillouby
Apr 28 2017, 01:25 PM
Ordered the Jegs pump today.
Will see what happens.
To help with the new pump I will sell the Davies Craig pump and parts I have.
New never ran.
200.00
