After only 7500 miles on a 914 conversion to fresh six and 901 gearbox, the new flywheel ring gear was trash. The drive gear on the Bosch starter showed no damage or unusual wear despite catastrophic destruction of the ring gear. The starter was returned to the auto-electric shop where it was serviced prior to installation, was inspected and no problems found but replaced the drive gear. We also verified it was the correct starter for the application. I did a "hardness" test on the flywheel teeth with a file and didn't feel much different than mild steel but it sprayed sparks when hit with a grinder. Inconclusive.
Logically the starter drive gear should fail before the ring gear (small gear/high revs vs big gear/low revs) at a ratio of about 14 to 1 tooth contacts per revolution. So----why did it fail?
Heck if I know.
I counted 36 listings for flywheels on ebay that fit 65-69 911 & 70-71 914-6. The vast majority are from one of two German OEM manufacturers, WD Express and Sebro. The market is flooded with WD Express. The Sebro could be as much as $100 more than the lowest WD Express if you consider shipping (some not free). Anyone have any experience or knowledge of either of these OEM flywheels?
How about plan B, farm it out and replace ring gear only (weld on?)
