brant
May 9 2005, 10:35 AM
I know the first thing people are going to tell me is to buy the aluminum AN wrench.
I will, but I don't think it will fit due to the width of those wrenches.
So the question is....
what size of wrench fits a AN-16 fitting?
I need to go buy one to facilitate easier oil changes on my project. I measure it out at 1.5 inches or 38mm... but wanted to confirm this with someone before calling a tools shop and spending the money..
anyone know?
brant
xsboost90
May 9 2005, 10:39 AM
make one!
Mueller
May 9 2005, 10:42 AM
#3 AN (1/2" hex)
#4 AN (9/16" hex)
#6 AN (11/16" hex)
#8 AN (7/8" hex)
#10 AN (1" hex)
#12 AN (1-1/4" hex)
#16 AN (1-1/2" hex
brant
May 9 2005, 10:48 AM
Cool..
thanks a ton mike!
so my rough measurement was pretty close.
and it looks like I should buy an american size instead of metric then (might be cheaper anyways?)
brant
Ferg
May 9 2005, 10:50 AM
Brant,
come by tonight, and look at the one I use for my car. Our AN fittings may be different but i think mine is 36mm. I use a headset tool for my bike, it's super thin and cheep, works ok...
ferg.
ArtechnikA
May 9 2005, 10:54 AM
just get Summit's complete set - they're much less expensive than some of the ones, especially purchased individually. eventually, you'll need the AN-3 and AN-4 fpr brake and clutch lines, and AN-6 for fuel lines, and...
also - there's two sizes to every fitting... there's the B-nut, which is the standard fitting size, and there's the size of the hose end (the "hose clamp" part - i've forgotten the terminology...) that screws down onto the cutter. that part's bigger. when you're assembling hose ends, it's really nice to have soft wrenches for both parts.
