Evan0
Apr 30 2017, 10:12 AM
Update 3 PostI've been rewiring my car for the last few weeks and part of that was replacing the factory fuse panel with one that uses modern fuse from JWest Engineering. I was unhappy with the existing relay sockets that I found. As a result of that, I designed and printed a monolithic fuse socket for all the relays, buzzer, and flasher unit.
After mounting it to the fuse panel. The buzzer is a Hella H35394001. The horn, blower, and fog relays are Hella 933332051. The flasher unit is a Hella 009492101. The head light relay is a modern reproduction of the VW one. Still waiting on the flasher unit to ship.
I'll be posting the STL files, Bill of Materials, and instructions after I've worked out a few kinks. I would love any feedback or suggestions on improvements.
Apr 30 2017, 10:35 AM
That looks great! How much would you charge to make one or a couple? I would like to buy. Thanks, mark
Evan0
May 1 2017, 09:34 AM
QUOTE(mepstein @ Apr 30 2017, 09:35 AM)
I'm working on a improved version. I wasn't happy with the clearance for wire routing underneath the dash with it installed. I'll update when new version is ready.
May 1 2017, 09:46 AM
QUOTE(Evan0 @ May 1 2017, 11:34 AM)
Awesome. Keep me in touch please.
BillC
May 1 2017, 11:29 AM
I am also interested.
JoeD
May 1 2017, 11:35 AM
Love it. I'd be down for one too. I've got the JWest fuse block and solid state relays in the engine bay... this would complete the trifecta!
Please let me know if you get to making more.
jd74914
May 2 2017, 11:06 PM
Very cool! Great idea as well. I'm quite interested; the old relays with their worn sockets always bothered me.
If you don't mind sharing-material and printer? The surface finish is better than any SLA machine I've seen and almost every SLS.
euro911
May 2 2017, 11:19 PM
Nice innovation
plymouth37
May 2 2017, 11:47 PM
Heck yeah! Nice work!
GeorgeRud
May 3 2017, 08:09 AM
Thanks for posting! As the round relays are getting more expensive, a cheap, modern alternative would be great. I love seeing this new technology applied to older cars.
Evan0
May 3 2017, 08:24 AM
QUOTE(jd74914 @ May 2 2017, 10:06 PM)
It's Zortrax ABS printed on a Zortrax M200. Most reliable printer I've ever used.
john77
May 3 2017, 11:50 AM
This is great. Definitely interested in one.
NS914
May 3 2017, 12:26 PM
Hi EvenO,
As the others have noted below....I would take one in a heart beat!
I too have installed my JWest Fuse Panel in as well.....those old relays are a nightmare...I still have not figured out how to get them to fit in the panel....your set up would be fantastic. Regards, Grant
Evan0
May 19 2017, 04:35 PM
JeffBowlsby
May 19 2017, 05:28 PM
What does the side facing the cabin floor look like?
Evan0
May 19 2017, 05:35 PM
QUOTE(Jeff Bowlsby @ May 19 2017, 04:28 PM)
913B
May 19 2017, 06:30 PM
That's cool, I would be interested in one too
clapeza
May 19 2017, 07:04 PM
Beautiful and functional!
Put me on the list!
Any chance of turning your attention to the engine compartment relay board?
Chester
JeffBowlsby
May 19 2017, 07:38 PM
I generally have concerns about the so-called 'upgraded' panels because many have proven to be problematic discovered only after a short amount of use. This set-up seems to have some positives.
The custom relay mounting base seems well done and using the new relays and fuses is commendable.
Don't like the cheapo side mount fuseblocks because attaching the chassis harness wiring stresses the wiring- using the flag terminals may address the tight fit but that means that all the original terminals need replacement.
PLEASE do not promote using those cheesy insulated terminals. Locate some solid brass double barrel terminals in the appropriate wire gauges as needed without the plastic insulator - because they are not a good long term solution.
bandjoey
May 19 2017, 08:20 PM
If you don't want to be a manufacture then license it to 914rubber for a % This could be a several thousand unit order when promoted.
Evan0
May 19 2017, 11:43 PM
QUOTE(Jeff Bowlsby @ May 19 2017, 06:38 PM)
Thanks for the advice regarding the terminals. I'll find the right flag terminals for final installation. Do you happen to know any of the troubles people have after replacing the panel? I would love to nip those in the bud before I run into them.
Addressing the replacement of all the terminals, my harness was mutilated by one of the previous owners, and everything under the dash had to be rewired and re-terminated. I don't have the resources to removed the entire harness and try to replace it with one in better condition. This is complicated by the fact that my car has had a LS1 swap and the electrical wiring is a bit iffy on the documentation.
This solution was designed primarily for my needs and definitely need further refinement before anyone else tries to use it. Suggestions and input like this is much appreciated.
JeffBowlsby
May 20 2017, 07:55 AM
The main issues I see are that:
1. The new fuse block mount on another version (not yours) had a metal strap that would short against the power terminal block on the 1970-72 cars.
2. The new stress put on the wiring to wire terminal juncture because of the side terminal locations rather than the original rear mount locations at the fusepanel. The ties organizing the wiring at the fuseblock needs to be loosened up or removed to give enough slack to connect the wires to their new side mount location. Stress on the wires over time will cause the wiring to fail at that stress point.
3. The new fuseblocks do not have the bussed together lugs that the factory fuseblocks do, so makeshift additional terminal busses are needed or the circuitry is altered to accommodate, making the factory wiring schematic useless for troubleshooting.
4. How well made are the new fuse blocks? The ones I have seen are of poor quality relative to the bakelite shell and solid brass fuse terminals of the factory original fuse blocks.
People have been replacing the original fuse blocks to use the new style fuses and because some say that they repeatedly kick out the fuses when getting in/out of the car. In 40 years of driving 914s, I have never had any issues with the original fuse blocks. I don't see any benefit to change the fuse block, personally.
Evan0
May 20 2017, 11:41 AM
QUOTE(Jeff Bowlsby @ May 20 2017, 06:55 AM)
Thanks for the info. I was wondering if that terminal block for battery power was factory or not. I will try to properly strain relief the wires as they are managed, but your right that it will eventually be an issue due to the tight spacing. The JWest blocks seems to be of good quality and it looks like the terminal blocks are properly bused together for 1-2, 3-4, and 10-12.
For the flag connectors, I'm going with the Molex Vibrakrimp series of connectors. They have a insulation grip, which will help offload some stress from the conductor itself. Again, thanks for the insight, you and your site are invaluable resources.
Jul 15 2017, 11:28 AM
Any updates. I'm still interested. Thanks, mark
Bartlett 914
Jul 15 2017, 11:46 AM
That is the best conversion I have seen. I hope you don't drop the project. Jeff offered some objective criticism which should help make this the perfect upgrade.
914Sixer
Jul 15 2017, 11:55 AM
I( agree with Jeff about the flag connectors. Can you simply turn the fuse block around and face the spades to the rear? Looks like that would be straight forward move and a solution to the problem.
Evan0
Jul 16 2017, 10:49 PM
I've just gotten my car going again this weekend, and have some changes and improvements that can be made. The board worked, but the current design had some problems during installation, and isn't suitable as a drop in replacement. I have plans for the next iteration that will hopefully be good enough to see the light of day on another 914. Thanks for the patience and constructive input, much appreciated.
NS914
Jul 17 2017, 11:17 AM
Hey Evan, I am actually into this right now and have been having a heck of a time to get my existing relays should back into the holes in the J West panel...your engineering and initiative would be just the ticket!
I see that after going through a few iterations you continue to develop it. Please put me on your list of future "me too" people.
Regards, Grant
raynekat
Jul 19 2017, 08:30 PM
I have to agree with Jeff Bowlsby on the after market fuse panels.
I'm doing a 914-6 conversion on my 1971 914-4 and I'm using an NOS 1971 chassis wiring harness.
I've also got a JWest aftermarket fuse panel.
The way this panel works is that the wires on the "inlet" and "outlet" sides of the fuse come in on opposite sides of the panel.
Where in the factory panel, the "inlet" and "outlet" wires come in on the same side of the fuse panel.
THAT IS A BIG DIFFERENCE WHEN IT COMES TO PLUGGING ALL THESE WIRES IN.
I'm seeing that there is a lot of stress on the connectors with the JWest panel and the main harness kind of straddles the panel vs being in behind the panel with the factory setup.
So I've decided to ditch the JWest with the new style fuse in lieu of the old fashioned factory style.
I can just tell the factory will be a much better setup.
Obviously the factory knew what it was doing.
raynekat
Jul 24 2017, 05:35 PM
This gives you an idea.
On the factory fuse panel, both the incoming and outgoing wires come from approximately the same direction from the main wiring bundle.
(A) On the after market panels, the incoming wires must loop around to the backside of the connection block.
It seems like this would put a lot of stress on the wire/connector on that side of connection block.
These incoming wires are just not long enough coming out of the main wiring bundle to make the journey relatively stress free.
(B) One option is to move the main wiring bundle such that it straddles the connection block, but again the direction change that both the incoming and outgoing wires make from the main wiring bundle to the connection block is not idea.
In the end, I've decided to stick with my 40 year old factory fuse block design and live with archaic fuse technology.
rad23racer
Jul 24 2017, 11:31 PM
QUOTE(Evan0 @ Jul 16 2017, 09:49 PM)
I’m in Corona and would like to offer to help with this project. I have CNC and 3D printing available to me as well. In addition, my car is mostly disassembled so things are easy to get to.
Evan0
Jul 25 2017, 12:38 PM
Thanks for the input everyone. I have a drastically different approach to the problem than my original design. It should end up being a much better permanent solution as well as lowering the overall cost. I'm also working on replacing the existing fuse block as well with one better suited to the cable organization. I should have a couple units ready to test in a couple weeks if anyone wants to be a guinea pig.
Evan0
Aug 14 2017, 10:17 PM
euro911
Aug 14 2017, 11:12 PM
Very nice, Evan. With the solid-state relays you've employed, will this cure the load issue when running LED turn signals?
Also, this unit is all that's needed to supplant the J-West or Engman fuse blocks and relay unit(s)?
If you're still looking for guinea pigs ... I'm your huckleberry
Evan0
Aug 14 2017, 11:33 PM
QUOTE(euro911 @ Aug 14 2017, 10:12 PM)
It doesn't have the load issue with LEDs, but it does require that the turn signal indicator lamp be replaced with a LED bulb as well. It's a annoying limitation of the design. The integrated fuse and relay panel would be all you needed.
McMark
Aug 15 2017, 10:35 AM
That's pretty freakin' awesome.
euro911
Aug 15 2017, 12:45 PM
With Jerry's LED lights, Timothy's LED gauges and Evan's relay panel, there's some real nifty stuff available these days
McMark
Aug 15 2017, 01:44 PM
Thought of something...
While I love the wire color printed on the board, I thought some of the wire colors changed on different years. It may be better to simply label each connection with the original relay pin number (30, 85, 86, 87, 87a). If I were troubleshooting a car with that board installed and I wouldn't want to have to pull out and analyze the wiring diagram to translate wire colors to pin number and function.
On the fuse board, it would be prudent to add either a couple extra constant power connections and a couple switched power connections, OR add a couple extra fuses for add-ons.
GregAmy
Aug 15 2017, 02:32 PM
Aug 15 2017, 02:34 PM
QUOTE(McMark @ Aug 15 2017, 03:44 PM)
it would make engine conversions a lot easier to have the extra connections.
Love what you are doing.
JoeD
Aug 15 2017, 02:39 PM
Yes please!
914_teener
Aug 15 2017, 03:17 PM
I.m in after doing my latest "gremlin" project on my car.
Evan0
Aug 15 2017, 03:54 PM
QUOTE(McMark @ Aug 15 2017, 12:44 PM)
It's not a big deal to add the relay pin number to the labels. But can someone confirm if the relay specific wiring connections changed color from year to year and if the relay wiring is significantly changed year to year?
Not a bad idea to add switched and straight battery power to the fuse panel, I'll add that to revision B.
Do you guys have opinions on how the fuses should be labeled? Should it indicate the amperage and a function symbol? What would be best to accommodate cars from different years?
euro911
Aug 15 2017, 04:05 PM
... All of the above mentioned items:
Fuse position # ... 1 ~
Fuse rating for each position
Function symbol for each fuse position would be nice too
A couple extra fuse slots labeled 'AUX'
JeffBowlsby
Aug 15 2017, 10:05 PM
Yes different MY 914s have different fusepanel and relay circuitry. Fuse amperages and layouts changes too.
KISS. Just number the fuses 1-12 just like the factory schematics. someone else can figure out what goes where for the different years.
Evan0
Aug 16 2017, 12:04 AM
Another question, how critical is the angle on the fuse panel in relation to the harness bundle? Would removing the tilt negatively affect strain relief on the harness? Optimizing the design for injection molding with that angle is proving to be a pain and removing that tilt would solve many issues. Thanks.
Spoke
Aug 16 2017, 06:48 AM
Beautiful design. Looks really well thought out. Lots of good feedback from the guys too.
One question on the placement of SSR U6 for the low beam: Why is it turned around WRT to the other SSRs? With it's positioning, its exposed pad is not against the heatsink. Was this done for isolation? What is the theta-JC from junction to the EP versus junction to top of case?
JeffBowlsby
Aug 16 2017, 08:32 AM
I amm pretty sure - not positive - that the slant is to enable a better viewing angle of the fuses where it is mounted. As long as the terminals are oriented normal to the back of fuse panel there is no unusual strain condition at each terminal
Wondering...what is intended for a fuse panel cover? The stock cover indicates the functions of each fuse.
914work
Aug 16 2017, 08:42 AM
Wow cant believe I missed this thread.
Extremely nice work and commend your willingness to accept & incorporate the feedback !!!
Put me on the list~
76-914
Aug 16 2017, 08:51 AM
Impressive!
