Picked this up at Hershey without paying enough attention, only to discover the hole in the top of the mushroom cap. I ran across a comment that this is for a 914-6, so just wanted to confirm.
I believe you're correct. Since the -6s blow more air through the heat exchangers, it is probably to allow more heated air to ex cape when the flapper valves are closed.
rpc
Apr 30 2017, 03:25 PM
QUOTE(GeorgeRud @ Apr 30 2017, 03:20 PM)
Thanks for the confirmation, George. Guess I'll be posting a FS ad.
GeorgeRud
Apr 30 2017, 03:45 PM
It should still work for a -4 as well, just bleeds off more air if the heat isn't being used in the cabin.
rpc
Apr 30 2017, 05:43 PM
Yep, I would think so. But my guess is that the mushroom cap, pointed inboard, is intended to shunt the hot air back to outboard. Having the hole just allows hot air inboard. (But then wouldn't that be an issue for the -6's??) I'm new to the 914 world so what do I know. I'm just speculating.
914Sixer
Apr 30 2017, 06:43 PM
Yep, it is for a -6.
johnhora
Apr 30 2017, 07:50 PM
QUOTE(914Sixer @ Apr 30 2017, 04:43 PM)
Here's a couple of picture of the HEs on a 914-6 with a view of the heater "flapper box"
Thanks all. I believe this is an original part, not one of the recent repros. I'd be interested in suggestions for a fair price. It should go to a good -6 home.
