QUOTE(flamefront @ May 1 2017, 09:49 AM)
Thanks for the input.
Regarding the motor mounts, if I put the '72 cross bar onto the 2.0L engine, I'll keep the existing '72 rubber motor mounts in their place, correct?
there are 2 separate metal brackets on the 2.0 motor mounted to the engine block behind the fan housing...
you will need to pull the housing off I believe in order to re-use the single larger metal bracket on the block of your 1.7 you are taking out
I believe (but have never tried it)... that your old 1.7 bracket will bolt right on to the 2.0 block... allowing the use of the old style tail shift motor mount bar you already have....
then you should be able to keep all of the motor mounts the same as they were on the car prior to the upgrade
