QUOTE(The old uncle @ May 11 2017, 11:01 AM)
Ok I'm stuck and stupid. How exactly do I test the cht? Do I have to remove it? The wire insulation is cracked and separated in many places so I don't want to agrivate the problem.
You need to use an ohmmeter and check the resistance values between the wire lead on the CHT (the one that is inside that cover) and ground (say, the battery negative terminal). So, one lead from ohmmeter on lead of CHT, one on the battery ground. You will get a resistance value in Ohms (or in thousand Ohms - K-ohms). That value should vary with temperature of the head. For a 2.0, you should get something like the following:
At ambient temperature (e.g., engine cold), 2.85 Kohms (2850 ohms).
With a generally warm engine or around 200 degrees, 190 ohms.
The exact numbers are not that critical, but you should be in "the ballpark." If you see a high resistance with an engine that is warm, that's a problem -- that's going to make the mixture richer than it should be, as the ECU will think "engine is cold or cool, more fuel!" when in fact the engine does not need more fuel. That would potentially give you symptoms like you are describing of running too rich. A bad or failing CHT is very common for something like this (although it's not the only potential cause). In my experience, though, a bad CHT will generally prevent the car from starting or running more than a few seconds, which leads me to...
...the other thing to know is that it's not just the CHT itself. It's the whole wiring harness from CHT to the ECU. Based on your description of your wiring harness, your CHT could be fine but the wire that carries that back to the ECU may be bad. If it's broken, or breaking, or otherwise showing too much resistance, you're going to get the situation I described - too much fuel for the engine's condition.
If your CHT resistance values generally check out, then it's off to chase down another D-Jet suspect, like the MPS.
