QUOTE(80cap @ May 1 2017, 01:18 PM)
Anyone know a good carb rebuilder? A pair of Dells.
Brian
I don't, but depending on what needs to be done it really isn't that hard to do it yourself. This is coming from someone who'd never touched a carb until 12 months ago and has now rebuilt 3 sets. It's pretty much like adult lego. You can buy rebuild kits with all the gaskets, etc, and then just take one apart, throughly clean (just google how to clean carbs) and use the second one you didn't take apart as your guide for putting back together the one you just did.
UNLESS you have a problem with the throttle shaft and butterflies - e.g. slop in the shaft or the butterflies are out of sync and aren't closing completely. Then you'll need to send them out, because that's proefessional level adult lego
