QUOTE(srreality @ May 2 2017, 10:30 AM)
QUOTE(gcrotvik @ May 2 2017, 09:00 AM)
The "the horn ring, steering wheel, turn signal and wiper switch" are all on the outer column and are not in the way. Remove the 4 bolts that secure the column to the shell. Have a second set of hands hold the attached steering wheel to pull it forward a bit. Loosing the bolt won't help it slide into the upper u joint. The bolt pins it in place on the shaft. Remove it but don't pull the shaft completely out of the upper u joint.
It might be best to remove your knee pad while doing this.
Luckily, I haven't installed the knee pad yet.........that was last item on my "punch list".
Thanks for the tips! Makes sense to me. I'm off to the garage to give it a whirl.
Well, as usual on this car, 3 of the 4 bolts loosened up with "persuasion".....the 4th resisted all efforts, tools, curse words, black magic, etc. so drilled it out. Tomorrow I'll see if I can finish the job.
