Brand New set of 4 Nitto NT05 for $350 plus shipping and paypal fees.
(These are 450 to 600 in stores)
Please see specs
http://m.nittotire.com/passenger-tires/nt0...rformance-tire/
The NT05™ is a max performance tire engineered to complement the power of your vehicle. It was developed through extensive computer simulation modeling and on-track testing. The rigorous development process helped produce a street tire that provides precise and responsive handling and performance. Knowing the tire is responding to your inputs will inspire your confidence.
FEATURES AND BENEFITS[quote]
A Perfect Pair
For even greater drag performance, the NT05 max performance tire can be paired with the NT05R drag radial on the rear axle. When developing both product lines, Nitto matched the tread design and sizing to fit modern performance vehicles.
Dry Performance
The continuous center rib combined with large outer shoulder tread blocks provides consistent contact with the road for a high-level of dry performance.
Predictable Cornering
The specifically formulated tread compound and reinforced internal construction were engineered to emphasize dry road response, traction, handling and high-speed capabilities.
Handling Stability
The reinforced tread blocks and the large continuous center rib provide exceptional rigidity and stability.
UTQG TREADWEAR*
200
TRACTION
AA
TEMPERATURE
A
UTQG TREADWEAR*
140
