While at a photo stop on Rt66 this year my 72 mostly stock 4-banger would not crank. Battery is fully charged, alternator light goes out when running, starter, alternator and battery each have 15K miles since new. Headlights do not dim when attempting to crank. FLAPS 12V "hot start" relay installed. No idea how old the ignition switch is.
I push started and it fired right up. It cranked with the key after lunch and when stopping for fuel on the way back to Idyllwild. The next morning it would not crank. I checked and wiggled the wires on the starter and relay, tried it again and it fired right up. Started no problem 3 more times on the way home. I tried a restart after shutting it off in my driveway and nothing. Came out the next morning and it fired up.
I bought a proper Ford starter relay which I will install using Mark Henry's procedure but I'm not sure that will fix the problem. Once or twice while starting it seemed like the starter didn't engage until the key was turned a bit further than normal but I could just be imagining that. I have a new ignition switch I could install but I would really like to isolate the problem first. And I don't want to fiddle with it at WCR.
Any ideas on what/how to troubleshoot before I start throwing new parts at it?
TIA
