The upper dash pad isn't difficult to install. Though the process is MUCH easier if the entire metal dash frame is out of the car. The dash top has to come off, and you may need to replace the thin foam under the vinyl. Make sure you use Sa-Besto, DAP Weldwood or some other very strong contact cement to hold the edges down...as that area can be exposed to high temps in summer heat.
Here's a link to some install tips...
http://www.914world.com/specs/Dash_top_vin...tallation-1.phpAgain, if you remove the dash frame (a few interior screws on each side, and 4 nuts in the cowl area), you can use clamps instead of popsicle sticks or whatever to keep the edges glued down. The hardest part of removing the dash frame is taking out the climate control unit.
Just type in "914world & XXXX" in google and you can find pretty much anything on this site....
