Dr. Roger
May 9 2005, 11:13 PM
Just go to ....
ftp://grubbenterprises.com/pub/It's the three big files. If there is anything else in there you see, I didn't putit there....
Andyrew
May 9 2005, 11:37 PM
I could only get one of them to work....
Paul.. Residential area.....
Dr. Roger
May 10 2005, 12:23 AM
it's the 3 *.mov files.
jonwatts
May 10 2005, 12:26 AM
You need to get out of your neighborhood and onto some deserted roads.
skline
May 10 2005, 12:32 AM
That is some bandwidth you have, it downloaded all 3 files in around a minute. Way fast.
smrz914
May 10 2005, 12:40 AM
I wasn't going that fast. BTW these were pretty much before I started and body work. I have more pictures on my site. Right click and save as.
Thanks again for hosting these rogergrubb.
Andyrew
May 10 2005, 12:46 AM
So....
Drive it lately much??
skline
May 10 2005, 12:47 AM
I need someone to ride with me and shoot the video. Its hard to shift and drive and hold the camera at the same time. Any local volunteers? I promise to drive safe.
smrz914
May 10 2005, 01:28 AM
She's out of commision untill I get to do some rust repair. Last time I drove her was in january. she's 160 miles away while i'm up at school. Sooo want to drive her again. It's such a thrill, so much torque, probably more then I should be running.
There is a lot of ticking in the background, thats my fuel pump. It's a facet pump and is mounted on the engine side of the firewall behind the pasenger seat. Then there is also the roof squeeking.
skline
May 10 2005, 07:09 AM
QUOTE (smrz914 @ May 10 2005, 12:28 AM) |
There is a lot of ticking in the background, thats my fuel pump. It's a facet pump and is mounted on the engine side of the firewall behind the pasenger seat. Then there is also the roof squeeking. |
Mount the fuel pump on rubber mounts down under the battery and take the top off. Mine squeaks from the control arm bushings so that I will have to change them out and install the rollers I bought. But for now, I can live with the squeak.
Aaron Cox
May 10 2005, 11:54 AM
QUOTE (skline @ May 9 2005, 11:47 PM) |
I need someone to ride with me and shoot the video. Its hard to shift and drive and hold the camera at the same time. Any local volunteers? I promise to drive safe. |
when?
MattR
May 10 2005, 12:10 PM
QUOTE (skline @ May 9 2005, 10:47 PM) |
I'll stop by thursday on my way home scott. Will you be home around 6ish?
skline
May 10 2005, 12:13 PM
QUOTE (MattR @ May 10 2005, 11:10 AM) |
QUOTE (skline @ May 9 2005, 10:47 PM) | I need someone to ride with me and shoot the video. Its hard to shift and drive and hold the camera at the same time. Any local volunteers? I promise to drive safe. :evilgrin: |
I'll stop by thursday on my way home scott. Will you be home around 6ish? |
It all depends on if they get to my letter at the dispatch hall. So far they are only at E, I am letter O.
