QUOTE(jim_hoyland @ May 12 2017, 09:14 AM)
I had two very uncooperative seat belt retractors; I came across a simple fix on-line; place the entire retractor with the belt still in place into a bucket of hot-soapy water. Leave in overnight. Next day rinse; then pull the webbing out to dry. The mechanism will drain, don't worry about it rusting. Then open the end with the pawl and lightly lube. Do NOT open the end with the spring.......
My retractors work like new since.....
So I contacted Snake Oyl last month about restoration for my seat belts based on the feedback I've read here and they said they couldn't do it. I have a 73 with the retractable belts. I provided pictures of every angle with the belts rolled and unrolled. Based on the positive feedback for them here I'm disappointed in their response but delighted to see this posting.
What kind of soap - dish detergent or laundry detergent?
Why not worry about rust?
Which is the end with the spring, the bigger end?
On mine, The finish on the bracket is rough. Any suggestions? Was thinking of hitting it with a dremell and polishing.
What about the chrome on the guide bracket? Where can I get these re-chromed?
Thanks in advance for the comments.
