QUOTE(Redraptor @ May 16 2017, 11:27 AM)
I have read around, thought about it and wanted some fresh opinions. I am in the process of stripping down my 74 2.0 and since I am going to take it completely apart I want to upgrade what I can while I'm here. The engine will not turn freely so the block is likely coming apart as well.
Here is what I plan on doing so far:
Replace and upgrade brake system
Replace upgrade exhaust system
Stainless steel fuel lines
Replace and upgraded starter
I havent seen the pistons yet but I'm likely going to have to do some upgrading there too.
Sway bars are going in too.
What else do you guys recommend doing? I don't care if she ends up being concourse or a racer, but I want her to perform well and reliably on the road. I want to do these changes by myself since I am going to pay a body guy to fix the body.
Brakes,stock is fine if all the sum of the parts are new or reconditioned .
Exhaust,choose the right upgrade and get a little more power.
Fuel lines,yes.
Starter,stock is fine with good wiring and ignition switch.
Pistons and cylinders,small power gain going to 96mm, is the engine FI or carbed? we don't know.
Sway bars ,add front one if you don't have it,the rear one has little effect because it is rather small,I have one because it was on the car when purchased.
I will add some stuff,horses for courses and some may not agree,but I don't do stuff I don't need;
Gearshift, upgrade to all the latest innovations and stock parts for improved shifting ,upgrades....Tangerine Racing has that covered.
Lighting ,upgrade headlights to H4 or better.
Electrics ,go right through the lot otherwise you may do too much
,ask me how I know.
Roof,replace all seals these buggers can leak, trust me on that.
Ignition switch , replace it cause it will fail, its not if, its when.
Curt made a good point ,sort the bodywork first and slowly buy up parts needed for the rest of the car during this period,don't expect to have the bodywork sorted cheaply as there is always more rust hiding that you won't see.
There is no such thing as a rust free 914........
you are in the BEST place.
