QUOTE(RangerDick @ May 15 2017, 10:31 PM)
Wasser Boxer guy but picked this up a few months ago. Purchased by my father brand new in 1973 from Neufeld Porsche in San Carlos CA. Had it in his hanger, but he sold his plane and needed to "get rid of it." So I got it for free. 1973 2.0 with the appearance group. Prolly a few hundred thousand miles, but rebuild engine with euro spec parts. No rust, Cali car. Original with MFI. Needs a good going through, with new rubber, brakes, engine drop and go through. Interior is nearly perfect, since driver's seat has one small hole. I have the original radio. Only stupid thing is my brother installed a clifford alarm and there are a bunch of wires that have been cut and spiced.
Paint is the worst issue, not too bad, but with minor fender benders, the localized respray doesn't match too well. Any suggestions?
Love this forum and will be referring to it on a regular basis.
That's great Dick!!
Keep it in the family too, going forward.
.... & you have the history since new on it from your Dad, I'm sure, so collect all his past records, service receipts, window sticker maybe, etc., & those should enable you to put the correct actual mileage on it, plus see what was done, whether it's still the original numbers matching 2L, etc..
Depending on the build date, it probably also has the Performance Group as well (F & R Sway bars + those Fuchs 2L wheels - should have been 5 incl. spare).
However, it will have the electronic Bosch D-jet EFI - not the mechanical MFi (which was on that era's 911 6s of that era only).
Get to know Rich Bontempi at HPH (High Performance House) down in Redwood City (he may have done the Euro 8.0:1 CR P/Cs for your Dad , it's one of his racer/AXer/Street trix), & Marty Yeoman who IIRC also has body work up there in the Bay Area.
Depending on the state of the paint - if it's 75% or more original & can be brought back by a quality detail shop/guy, then you may want to look at PDR & touch-ups only to fix those not-so-great prior touch-ups. However, if the original paint is too far gone, then you're probably going to do a full repaint - unless you just want to drive it as is.
You'll also find p914.com (& .org & .net), & Jeff Bowlsby's website below a great resource, & Jeff is in Pleasanton & does various 914 electric harness restos.
http://bowlsby.net/914/Classic/http://bowlsby.net/914/WiringHarnesses/So enjoy it &
Cheers!
Tom
