yes - replace the cam & lifters as a set, pushrods are not an issue,
you want a cam that is designed for carbs - google this for several good links
"camshaft for type 4 with carbs"
and be wary of bolt-on replacement cam gears since they can "come loose" and make a terrible knocking sound - be sure you properly secure the bolts & use loctite
split the case: most of us old-timers have btdt on these matters - hard knocks of experience when we had no internet to ask answeres of
QUOTE(JFG @ May 21 2017, 12:31 AM)
Thanks for the advice. Had problems with 009's in the past so will steer clear of them.
I didn't want to have to split the case but if i must so be it. If i do replace the cam (assuming next size up from standard) do i need to replace lifters & rods?
