QUOTE(r_towle @ May 22 2017, 03:50 PM)
I believe its a grounding issue behind he wheel.
Take it off and take a look at the contact that the red wire is using on the metal ring on the back side of that wheel hub.
That is how it gets its ground, so it needs to be a great connection, and super clean.
its two rings, one wire from below (brown/white) to the lower ring, and your red lead is connected to the upper ring.
rich
appears to be a short there,maybe the contact ring isn't right,but we don't know if its a stock one or Lecarra one depends on the boss used of course.
Just fitted momo adaptor and other aftermarket wheel,touch the horn wire to the wheel and all is load and clear.
