Car is Sold...thanks for all interest.
I have owned this car for 3 years , previous owner had it for 20 years.
Engine has about 8,000 miles since rebuild. 3 owners and most receipts back to original
Runs excellent and no issues. has owners Manila, toolkit and sales brochure.
This was a California car and has been kept in heated climate there is no rust .
Paint is mostly original with a few nicks trim and seals are very good .
Engine- new parts include
Flywheel
Sachs power clutch and thoout bearing
Main bearings
Scat street grind cam,bearings and aluminum cam gear
Scat solid lifters
Push rod tubes
Heavy duty oil pump
Mahle euro Pistons,rings ,cylinders
FI trigger points
New engine mounts
Crank was magnafljxed,polishes and balanced
Heads reworked with new seats guides and head to cylinder surface machined
Bursch Muffler
SS exchangers
Fuel System
Tank removed and cleaned
SS fuel lines in tunnel
All new rubber lines
Injectors cleaned and balanced
New throttle position circuit board
New fuel pump
New throttle cable with spare in trunk
Transmission
Fully rebuilt with assistance from Dr. Evil
New seals
New mounts
Shifts perfect with new shift bushings
Body
Very much original with respray 20 + years ago
Original windshield with factory VW stickers
Interior
All gauges work in excellent condition
MOMo steering wheel
Seats are excellent t one small wear spot
New carpets and Mats
iPod hook up with JBL speakers ,2 in stock location and 2 tweeters in coat hook location
Blaupunkt amp in front trunk
Rebuilt crank/tracks windows are smooth
All switches work ,rear defrost works, fuse box unaltered and stock condition.
Dash very good with one minor crack not visible from inside.
Many other great things about this car
I have attached a few photos , let me know if you would like additional photos
Or information.f
Ftorchia.aia@gmail.com
Priced at $16,500 OBO
Car is located in Chicago will assist with airport pickup if you would like a drive.
