Full Version: Mirror Hole Spacing
7TPorsh
My car is in the shop and I can't get this measurement. What is the spacing between the mounting holes for the outside mirrors?
bandjoey
If you're doing this for the passenger door the nuts are welded inside the door. Punch through from indide then drill carefully from the outside.
r_towle
30mm (1 3/16 ish)
Went and measured two bare doors, early and late....same.
Maltese Falcon
Gary...what bandjoey said !
Use a small punch that will slip nicely into a 6mm nut, gentle tap will do it. You will need to snap your door card (interior panel) off, and use a small hammer.
Marty
7TPorsh
I have already poked the holes on the passenger side. i am looking for some new mirrors. I am a little tired of the droopy stock look...also want something in black.
7TPorsh
QUOTE(r_towle @ May 23 2017, 06:20 PM) *
30mm (1 3/16 ish)
Perfect, just what I needed...Thanks!
Invision Power Board © 2001-2024 Invision Power Services, Inc.
