csdilligaf
May 24 2017, 07:05 PM
I have never seen them in action. Does the cable release a catch that allows them to pop open? Do they open slowly with the nitrogen piston or is it like a snap open? How do they get back down? Do you have to push them back down by hand? Or does the cable pull them back down?
tygaboy
May 24 2017, 07:16 PM
I've not seen them in action but yes, pull cable to release the catch and the hydraulics pop them open. (not sure how fast/hard). You have to close them by hand.
Here's a great place to learn all about it:
http://www.pbase.com/9146gt/gt_mechanical_headlight_raisers
ConeDodger
May 25 2017, 08:55 AM
Properly adjusted, you pull a release handle on the dash and they pop up. Your headlight switch only turns on and off the light. There are pictures in my project thread somewhere. I'll see if I can find them...
Just Another Damned Project Thread
ConeDodger
May 25 2017, 09:13 AM
7TPorsh
May 25 2017, 09:16 AM
I like this idea...here may be a way to make the lights pop open half way and put some low profile led lights.
VaccaRabite
May 25 2017, 09:29 AM
QUOTE(7TPorsh @ May 25 2017, 11:16 AM)
Easy enough to fab up some stops that would limit how high the headlights open.
Zach
VaccaRabite
May 25 2017, 09:30 AM
Someone also had a push/pull system in place at one point so that you did not have to get out of the car to lower the headlights.
Zach
barefoot
May 25 2017, 11:38 AM
QUOTE(Vacca Rabite @ May 25 2017, 11:30 AM)
Zach
The Saab Sonnet has push-pull headlights, probably some info to be found on their sites
jmitro
May 25 2017, 11:51 AM
how much weight is saved by doing the GT headlight conversion?
csdilligaf
May 25 2017, 01:46 PM
Thanks for the info guys. I wasn't sure if you had to push them down by hand. The kits seem pretty nice and well done. I know it only saves a little weight but its just one less electrical thing to go wrong and it has a cool factor since I love all things mechanical.
mb911
May 25 2017, 01:49 PM
QUOTE(jmitro @ May 25 2017, 09:51 AM)
Same question
914dave
May 25 2017, 02:06 PM
QUOTE(mb911 @ May 25 2017, 03:49 PM)
Same question
IIRC it was around 13#s.
gms
May 25 2017, 02:35 PM
although the weight savings may seem trivial it was one of many parts that collectively reduced the weight of the race cars. The added bonus of the headlight motor delete is that they lay outside of the wheel base at the very front of the car.
ConeDodger
May 25 2017, 02:44 PM
McMark said about #10# So 13# is in the ballpark. Especially if they pared away the unneeded wiring.
pete000
May 25 2017, 04:51 PM
Yup, on the list to do things...
jmitro
May 26 2017, 05:55 AM
QUOTE(gms @ May 25 2017, 03:35 PM)
definitely; couple lbs here, couple lbs there. it all adds up for a full race car.
VaccaRabite
May 26 2017, 06:48 AM
I read somewhere that the old formula was the removing 10 pounds was like adding 1HP.
But I've also read that painting ones car yellow will make it go faster, and that stickers add 5HP.
Still, removing 10 pounds should make a difference in your Power/Weight ratio. Those motors are heavy.
Zach
mb911
May 26 2017, 07:16 AM
Kits are kind of expensive but something I may consider when the time comes.
Marek
May 26 2017, 08:24 AM
I Am just finishing a kit, as part of the Gt Repro parts we are working on
with all you need to do this conversion
just waiting for the wires , should be here in 2 weeks
Will post pics and a for sale add ASAP
A kit will be 500 Euro incl shipping ,
and its spot on to original that was build on Magura bike parts
Marek
mb911
May 26 2017, 11:16 AM
