Not to steal 914forme's thunder here, but I was able to get my Zerodecibel Bell Crank shifter setup last night .
It is a very nice setup, can't say anything bad about it. Solid craftsmanship and zero fitment issues. Went together in about 10minutes by looking at the images on the website.
After a bit of adjustment in the heim joints on the MR2 shifter and at the bell crank shifter assembly I can reliably engage every gear. You can feel the gear engagement and shifting is very smooth. My 5th gear is a little tight to get into, but after the adjustment this became smoother.
All the parts required and prices are below that I used in my cable shifter setup
Toyota MR2 Shifter - $60 - ebay
Custom Control Cables - $178 - 7ft in length, part number 100-4222-0084
Custom Control CablesZero Decibel Bell Crank Shifter - $300 -
ZeroDecibel MotorSports Bell Crank ShifterParts list below is how I attached the Custom Control Cables to the MR2 shifter assembly
1/4-28 Heim Joints (2) - $9.87/piece - TruValue Hardware
3/8 Bronze Flange Bushing (2) - $3.12/piece - TruValue Hardware
1/4-20 Stainless Steel Bolt (2) - $0.85 - TruValue Hardware
1/4-20 Stainless Steel Nut (2) - $0.37 - TruValue Hardware
The 7 foot control cables could be shortened by a few inches, however, with 7 feet I am able to route the cables away from the engine and attach them to the engine cradle. Still need to make the actual attachment to the engine cradle, but overall, the system works great!
