azbill
May 11 2005, 08:20 AM
The west coast is going to miss the good Doctor and his talented hands. He did a fantastic job of assembling the guage.
He over can some problems with holes linning up. If you need a guage put togeather find the Doctor to do it.
Qarl
May 11 2005, 08:21 AM
Wow... they truly area magic hands... he made them invisible!
I can't see them.
azbill
May 11 2005, 08:22 AM
Need to add the pics - Front
azbill
May 11 2005, 08:23 AM
And the Back
michel richard
Invisible needle on the temp !
azbill
May 11 2005, 08:25 AM
The needle is there you just cann't see it
TravisNeff
May 11 2005, 08:38 AM
SLITS
May 11 2005, 08:48 AM
QUOTE (azbill @ May 11 2005, 07:25 AM) |
The needle is there you just cann't see it |
Must be running DTM technolgy....engine never heats up!
michel richard
May 11 2005, 09:24 AM
QUOTE (azbill @ May 11 2005, 06:25 AM) |
The needle is there you just can't see it |
That's what I said, invisible needle.
Dougs914
May 11 2005, 12:50 PM
That has to cost a
arm and some other
part to have done.
914werke
May 11 2005, 01:03 PM
Where did that guage orig. come from?
Root_Werks
May 11 2005, 01:55 PM
Soon that gauge kit will come from the land of Root.
Aaron Cox
May 11 2005, 02:03 PM
lower left idiot light needs to be coerced into place
aircooledboy
May 11 2005, 02:42 PM
Wow!!! Is that a great combo set-up.
Dan old buddy, you're gonna sell a bunch a them if that's what they are gonna look like. Me likie.
Dr Evil
May 11 2005, 02:56 PM
To straighten the lights all you have to do is put a pen in the back and reposition....sheesh. The kit was crappy. The holes for everything did not line up and needed to be "corrected" the best that I could. I also have a technique that allows me to put the light bungs in with out using the adheasive recommended. If they were glued, I have no idea how they would conduct groound.
I told Dan Root about the problems I had and he will make sure that his kits are top notch (of this I have no doubt). It was a PITA. If the kit was right it would have been so much easier.
Thanks for the props, Bill
Mueller
May 11 2005, 03:00 PM
looks good...the numbers for the "oil pressure" would drive me batty being tilted in that position
Root_Werks
Yep, hoping to make a run of like 100 of these. But it won't be for a little while. I have a feeling I will need to make a couple, assemble one, make another few, you know, R&D stuff. I don't want to powder coat them like the orignal kits either. Too much texture. I want to anodize the front plates. We'll see how things go.
There is a thread on this that was updated not too long ago.
914werke
May 11 2005, 05:50 PM
whatchu talkin bout willis
Is this a new gauage or a friggin refit on an exiting housing?
Palo Alto does a similar one. but is $
I think its Kewl but a little more detail please
azbill
May 11 2005, 07:03 PM
I bought the kit from Jeff Fort, the oil pressure and temp modules came from a 1984 911, the fuel module is stock 914. Mike Dr Evel assembled the parts. That where the guage came from.
Dr Evil
May 11 2005, 07:59 PM
Notice (if you can) that the low fuel indicator is a solid red now. My own personal modification
914werke
May 12 2005, 09:58 AM
AHHHH thank you So if you want one you will have to deal with Dan AND supply the 911 components?
Dr Evil
May 12 2005, 10:11 AM
Yup, I strictly do assembly.
Root_Werks
May 12 2005, 11:06 AM
QUOTE (rdauenhauer @ May 11 2005, 03:50 PM) |
whatchu talkin bout willis Is this a new gauage or a friggin refit on an exiting housing? Palo Alto does a similar one. but is $ I think its Kewl but a little more detail please |
Rich, I few years back this kit was offered I think for around $100-150. It was basically a backing plate and face plate with instructions on how to take a 914 and 911 combo gauge to make a 904 style gauge. I have assembled a few and loved the whole package/kit idea. I have the plans thanks to Aaron Cox and this summer will be re-tooling R&D the kit to make another run of them. it will cost $$$ and I don't really plan on making any real money from it. Really just want the kit availble again. Even with buying a used 911 combo gauge and this kit, one should be able to put a 904 kit together for under $200.
My goal is to offer the kit for under $150.
Dave_Darling
May 12 2005, 12:12 PM
I would suggest modifying the backing plate so that the fuel gauge part can use the standard later (72+) fuel gauge modules. To do that, you drill holes in the same pattern as those used on the other two gauge modules (oil temp & oil press) but rotated around the center of the backing plate to the position for the fuel gauge module.
Finding the early gauges can be a bit of a pain, and having to de-solder and re-solder them is definitely a pain. If you make the above mod, you can use the later style bolt-in fuel gauge module. You wind up needing to use the 911 gauge housing as the housing for your new combo gauge, but that's quite easy to do anyway.
--DD
(Who did the above mods to his combo gauge kit.)
Root_Werks
May 12 2005, 01:39 PM
QUOTE (Dave_Darling @ May 12 2005, 10:12 AM) |
--DD (Who did the above mods to his combo gauge kit.) |
Already have it drawn into some modified plans. I don't want there to be any soldering required.
