QUOTE(euro911 @ May 29 2017, 12:04 PM)
Could be abnormal wear from the races not fully seated when initially installed, not enough grease in the bearings, excessive hard cornering, axle nut not cinched tight enough and un-threading
Do you tighten the axle nuts real tight after installing new bearings/races, then back the nuts off before cinching them with the Allen bolts?
Did you properly seat the bearing races? I would pull a wheel and inspect. Did you use quality ( non Chinese ) bearings ?
And this should be in the Garage forum not Parts for sale forum.
Bruce
