Jaymann
May 29 2017, 01:32 PM
Rear trailing arms SOLDThey have been stripped, and powder coated. One is early,one is late.So you would have to modify,one bracket,to use as a set. 200 + shipping.
gcrotvik
May 31 2017, 11:11 AM
Just an FYI. The trailing arm with the closed brake line bracket is an early (70-72.5) trailing arm and the other with the open (slide through) brake line bracket is a late (72.5-76) trailing arm. They both function the same but they are different years.
bdstone914
May 31 2017, 09:41 PM
The difference is that you need to modify one of the brackets to accept the flex line to use matching early or late flex hoses.
Bruce
