QUOTE(RickS @ Jun 22 2017, 10:42 PM)
Thanks Bill,
Looks like the way I have them now is doing next to nothing since the slotted arms now look like this: \\ I will move them to horizontal and adjust the drop links so there is zero preload.
My new understanding is that drop links are adjustable for initial setup at zero preload and they are left at the initial adjustment but moved up the slotted arms to dial in more preload.
Don't confuse preload with the firmness (or "strength") setting.
Preload is when the sway bar is pushing down on one side and lifting up on the other while the car is sitting still. Sometimes (rarely) there's value in putting preload on the bar, such as for oval-track racing. However, normally, you don't want any preload.
What you want to adjust is the firmness setting. The sway bar is a torsional spring, and the formula for torsional load (aka, torque) is force times distance. Since the "force" of the sway bar is fixed, due to its construction (diameter, length, material, etc.), the only adjustment you have for torque setting is the slots in the arms. Moving the point where the droplinks attach to the arms closer to the sway bar will increase the torque required to move it, and will effectively make the bar stiffer. Moving the links farther from the bar will soften it.
Normally, making a bar stiffer will "transfer" traction to the other end of the car. So, if your car understeers, you either want to make the rear stiffer or the front softer. Conversely, if it oversteers, make the rear softer and/or the front stiffer. However, you should only make one adjustment at a time and then test it. If you make two (or more) adjustments at a time, you won't know which adjustment had which effect, and could end up making the car worse without knowing why or how to fix it.
