djsinister702
May 11 2005, 06:26 PM
I did one ...work great on mine..
anyone else put one on their????
djsinister702
May 11 2005, 06:28 PM
tat2dphreak
May 11 2005, 06:32 PM
I probably will, but my seal is in good shape... when I did drive my teener, the top was always in the trunk... no point in fixing the seal...
tracks914
May 11 2005, 07:11 PM
I'd like to one of those $8 front Targa seals.
hmeeder
May 11 2005, 07:30 PM
I put one together about 3 years ago according to Pelican's Tech Article and was very happy with the result. My change was to use Automotive "GOOP" instead of the rubber cement. I used 2 sections of 2x4 as clamping surface and allowed a day for it to cure for the section where you flip the segment backwards. I have had it in place for a quite a while and it works pretty damn good. Just now the surface is beginning to get some pitting. The rubber isn't the kind of quality the OEM seals are, but for $8 (prolly closer to $12 actually) you can build a new one every several years and still come out way ahead.
my $02
Demick
May 11 2005, 07:37 PM
I wrote that article 7 years ago now I think. It's still on the car and showing no signs of any deterioration. The only thing I did in addition to the article was to run a bead of the Permatex weatherstrip adhesive down the long seam created when you fold and glue the seal together. In warm weather, the contact cement began to peel apart - so adding this bead of weatherstrip adhesive holds the seal together much better. Haven't touched it (or even thought about it) since I did that - which was about 6 years ago.
Demick
djsinister702
May 11 2005, 07:49 PM
Demick...
you did that????? awesome..thank,
yes i just did one....i went a step farther and use the left over to cover up the chrome trims...which make the fitting nice and tight....
