This unit was on the car at purchase. It's basically a kill switch. It connects to my negative battery post and the battery cable. The cable tightens to the top end of the unit. The nut in the middle of the unit can be tightened for connection or loosened to break the connection.
The problem is that I discovered that the clamp end that should tighten around the battery post is too large to snug against the post. Can I line the post with something to allow this unit to be snugged against the post...or trash it?
I assume all battery posts were the same in diameter. Am I wrong?
Thanks,
DanClick to view attachment
