Hi all,
Yes, the "third" clutch adjustment on a new cable confirmed that I have a broken tube and I hoped it would end at a couple of repair ports. Unfortunately during my detailed inspection I found previous floor repairs (held for maybe 30 years) but a wee bit of rust crept in and stressed the firewall to the point of a tear from the floor and subsequent stress shear.
I know what I need to do, I'm just looking for opinions from someone who's been there. Inga is in the process of dismantling and here are the relevant bits:
1. Rust is confined to the area aft of the inner bulkhead support. All from within appears solid and unmolested.
2. The bulkhead tear is confined to the "droop" in the centre of the bulkhead. It appears that the damage started at the seam, though the floor extension appears good.
3. There is rust-through on the DS "last rib".
4. The DS jacking point appears solid, but the "inner triangle" of the piece is AWOL (I found a fibreglass "wadge" quite well concealed.
5. There is little or no evidence of rust inside the bulkhead; all the other substructure appears intact (including the HellHole)- a PO did a similar PS patch as I now need.
The "lumpectomy" is to be done this weekend to provide access. I have two general questions:
1. "Tech Tips 700" power plant removal vs. Pelican?
2. Fabricate repair panels vs. replacement?
I'm ready to get a shot bag and metal brake (I have everything else) but I'd like to avoid finding more surprises and changing horses mid-stream... this is where you all come in. Anyone?
