QUOTE(914Sixer @ Jun 5 2017, 05:01 PM)
The drilled holes were drilled to balance the fan. By taking the black housing off the fan will now be out of balance. Probably done to counterbalance the missing fan blade
Not exactly. The fan blade was lost when my alternator bolt came off and ended up in there.
The unmarked hole filled one I got from the swap meet this weekend. The lower black parts look identical and just bolt on and off. They each have weight added as a strip of metal inside.
Does it need to be re-balanced?
