I have the stock temp gauge in the counsel,its an all original 74 2.0. It stopped working but the needle does move slightly when you click the key. What are a few possibility's and where is the sending unit located on the case.
914Sixer
Jun 5 2017, 06:05 PM
Bad sending wire from the sender, bad plug under battery. Sender and gauge rarely fail.
Tom_T
Jun 5 2017, 10:18 PM
... the sender is in the "Taco Plate" on the engine underside.
Also check & clean your terminals & connectors at the back of the gauge to the console harness, & at that harness to the main harness in the tunnel - clean & add diaelectric grease or oil (Wurth has a good spray oil).
Tom ///////
