QUOTE(Biggles @ Jun 9 2017, 02:33 PM)
Hi All,
can anyone please confirm the correct H4 Hella headlight part number for use in the UK ? i.e. driving on the left. The PET doesn't show it just the porsche part number.
I've got sealed beam US units in mine and want to replace.
thanks
Chris.
Hi Chris,
The easiest way to see where an E-code light is to be used is to look at the line for the "cutoff rise" in the lens. For those that drive on the left (UK, Japan, Oz, etc) that cutoff line is at the 8 o'clock position. For rest of us, the line is around 4 o'clock. A couple of other tells: Cibie and Marchal both use a "TG" (for "traffic gauche") after the part number for lenses for left-hand traffic. Finally, lenses for left-hand traffic will usually have small arrows stamped into the front of the lens (usually under the "E2" or other qualifying E-code); they point to the side of the road you drive on.
I'll see if I can attach a couple of pictures . . . .
