I installed my 914 front bumper top two months ago but just now got around to "taming" the ends. Darren C covered this in his build thread( http://www.914world.com/bbs2/index.php?sho...47250&st=60 day 164)but did not provide much detail. Anyway, here are a few pic's of mine being tamed. In this first pic you can see how the ends look once the bumper top is secured to the bumper. And yes, I know my bumper is dirty.
Notice how I center punch a wee bit inboard of center. This was to give myself a bit more room to turn the screwdriver from inside the bumper. If the hole is too close to the bumper (the place where bumper & rubber meet) you will play Hell turning the screw with a screw driver.
This is where I varied from Darren's method. Rather than remove the rubber top I simply maneuvered it to one side whilst drilling.
Once the bumper is drilled, pull and hold the rubber end in place then using the hole in the bumper as a guide, insert a "push pin" into the rubber. This will mark the spot you'll need to drill the rubber.
Drill out the rubber paying close attention to the angle of the hole. You don't want to pop out the side of the bumper top.
You can see why I drilled a bit off center as you need all the room you can get to tighten the screw.
With the screw tightened the edge pulls in quite nicely.
