QUOTE(914bee @ Jun 11 2017, 09:01 AM)
I have new center caps for newly refinished Mahle wheels painted for the Bumblebee. The caps that came with the car are from vwispwest a VW parts supplier. I don't see them from Porsche so who has the best example to the original? Also, the fit of the center is too tight to get them even started so I suspect material may need to be removed. I need some direction!
ISP West sells a repro
billet aluminum, so you may need to turn them some to get them to fit properly, check with them first about the fitment problem to make sure that you got the proper ones (they may have larger ones to fit other wheels with bigger center holes.
For original type - Porsche Classics is making the factory ones again, but they are more pricey than the billet repros (billet is more sturdy for a DD IMHO).
Try either Sunset Porsche & Suncoast Porsche Parts Depts. for pricing on those, & you can see them on the main Porsche website, under the Classic Parts section to get the part no. & retail price (those 2 dealers should be less).
Make sure to have them give you best price for 4 from both single & "set of 4" - cuz Porsche Classic had priced the set more than each x4 for some odd reason (Jeff Bowlsby found that bass-ackwards quirk for us all).
PS >>
http://www.classicshop.porsche.com/pcos-us.../wheels-brakes/PSS >>> It looks like they solved the pricing discrepancy by removing the single cap item at their website, but still ask the dealers for best price between the set of 4 & 4x singles....
http://www.classicshop.porsche.com/pcos-us...cg36130307.htmlGood Luck!
Cheers!
Tom
