Jeff - all USA tires have the DOT date code, & it should be in that oval area at the top of the pic on the sidewall, & each tire should have one, but sometimes the tire shops are doofus & mount them on the inside face.
https://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=11PS - Nice looking wheels, but next time make sure they mount the sticky weights on the inside of the rims, so they're not a "zit" on an otherwise beautiful wheel(s). They may argue, but it can be balanced that way, & they'll need to clean the inside faces to bare metal so that they'll stick. Shoot, that one the guy could've attached inside through the dang hole, & your inner rim looks as clean as the outside!
Tom
