Well okay, here is my question. Is there a way to install the rear calipers without taking the inner adjustment cover screw off?
I just can't seem to get it past the lip of the access hole in the trailing arm.
Thanks!
QUOTE (mihai914 @ May 12 2005, 05:16 PM) |
If it's the original allen head screw I believe you can take out the caliper w/o removing the thing. If it's a replacement bolt type then it has to come off, I wish they would of made those things a bit skinnier |
QUOTE |
bill. you going to be home arounf 11 or noon? have a CPR recert class at 10 at the city hall, figured id drop by and see what your upto |
