doug_b_928
Jun 13 2017, 08:11 PM
The adjusting nuts on the cables were seized, but I managed to get them free and adjust them so that the maximum amount of slack is available on the cockpit side of the park brake cables. I was thinking that I'd then be able to simply remove the cables from the 'swivel attachment plate' (where both cables attach to the plate that, in turn, attaches to a cable that, in turn, attaches to the parking brake handle) but there doesn't seem to be enough slack to accomplish that. Is there some technique to manipulation the connectors on the 'swivel attachment plate'? I'm sure this is really easy and I apologize for the dumb question, but the answer is escaping me (I'm very gentle with things so perhaps getting a pair of pliers and really pulling on the cables to get them around the curve of 'swivel attachment plate' is the solution???).
iankarr
Jun 13 2017, 08:22 PM
No prob!
There are pins securing both sides of the short cable connecting the swivel plate and the handbrake lever. Undo one of those pins to relieve the tension.
doug_b_928
Jun 13 2017, 08:36 PM
Excellent, thanks! I'll give that a go.
doug_b_928
Jun 14 2017, 03:29 PM
I got those pins out, but it wasn't easy. They were quite stuck. One of them is really corroded and deformed. The clip that holds it on disintegrated when I tried to remove it. Anyone know if these clips and pins are available anywhere? Here is a pic of each:
Click to view attachment This is the good pin
Click to view attachmentAlso, I cleaned some overspray off of the parking brake handle with some acetone. It removed the overspray but also seemed to screw up the finish on the handle (it's kind of sticky now). Anyone know a way to restore the finish on the handle or is it replaceable?
Jun 14 2017, 04:51 PM
Eric at pmb performance told me he has them in stock. They are pretty cheap. Once rusty, they break pretty easily.
Eric might also have the rubber grip. If not, try 914 rubber or your Porsche dealer.
doug_b_928
Jun 14 2017, 04:52 PM
Great, thanks. I'll add these to the list of things to get from him.
iankarr
Jun 14 2017, 08:08 PM
You're lucky they didn't completely rust-weld. I had to drill mine out. AA carries the pins, but they're a bit shorter than stock and wouldn't work on my car. Best to get them from Eric....
doug_b_928
Jun 14 2017, 09:18 PM
Yeah, drilling was my next option (I'd already tried the hot wrench). Thanks for the tip re the AA pins.
