QUOTE(edge540 @ Jun 17 2017, 02:36 PM)
Makes complete sense now. Its the Weltmeister. For some reason i thought the bottom of the shift lever had a ball and socket setup but now i see that was for 70-72 and the 73-76 has the fork type setup.
Thanks for clarification!
Eric
PS, I bought the car with this installed. If i wanted to go back to stock its just replacing the gear shift lever and removing the spacer?
Yes, get a stock shifter and remove the plate. You will need three shorter 8mm screws because the ones in the kit are longer to reach the tunnel with that spacer.
I did the same when I bought my car 8 years ago. Make sure you have fresh bushings everywhere in your linkage and you will appreciate the shifting.
Oh, yes you are aware that there 2 versions of the shifter. The lower part is different on the 72 and earlier cars but it's obvious.
Good luck.
