srreality
Jun 19 2017, 11:01 PM
My steering wheel and horn assembly came to me in pieces. I've reassembled them, along with new turn signal switch. The turn signals work fine, but don't cancel. The horn contact ring on the back of the steering wheel has an "arm" on it the must be there to nudge the signals off.....which side of the wheel should that arm be on? Does it go on the turn signal lever side or opposite that? Sorry, I don't have any pictures, but I figure one of the experts on this forum knows the answer.
malcolm2
Jun 26 2017, 07:56 PM
lever on the left, small pin moves in toward the column on the right. the W shaped spring moves up and down too. the tab on the horn ring travels in the gap between the column and the lever housing.
