JFG
Jun 21 2017, 01:06 PM
I'm onto the gearbox now that the engine is back together.
I have new output shaft seals but i thought there were holes to put a bar through in order to lock it while i undo the bolt. I was wrong they are just indentations.
Is there any way i can lock these off or will i need to take the box to a garahe for them to blast the bolts with an air gun?
Jun 21 2017, 01:28 PM
Put two bolts in the flange and use a bar to hold the flange while you're turning the center bolt.
mark04usa
Jun 21 2017, 01:32 PM
IIRC the torque on the bolts is about 31 ft lbs, so should come off easily (I was lucky and mine were easily R&R'd). Be sure not to set the seals too deeply or they will fail and leak quickly as mine did...I had to do this job twice!
JFG
Jun 21 2017, 01:46 PM
Thanks for the info. i wasn't sure about the torque figures so got a bit worried. Nice tip about seal seating, i definitely don't want to do it twice!
Justinp71
Jun 22 2017, 12:07 PM
I need to redo mine. I plan to knock the seal flush with a piece of wood. Then take a piece of 2" PVC pipe to knock the seal flush with the case.
I had the issue with the seal tearing on install last time, any reason why I can lube up the back of the seal with some trans fluid to help prevent tearing?
