rd914
May 13 2005, 03:23 PM
I need to replace all tires on stock Pedrini rims. What is the max tire width can I replace it with? It currently has 165 SR 15. Advise please.
Mueller
May 13 2005, 03:41 PM
normally you can get away with 205's in width, 50, 55 series most common....I've seen one car with 60's, but they looked too odd, like ballons (hey Mike
skline
May 13 2005, 03:45 PM
Dan Root's new car has 205X50X15's mounted on stock Fuch alloys. They fit nice and really grab the road. I dont know if it can be any better.
rd914
May 13 2005, 04:03 PM
Thanks. I'm gonna go with 205/50/15s.
bd1308
dont go too wide for that rim tho, it'll mushroom and you'll be all over the road
bd1308
May 13 2005, 04:04 PM
I have the ZIEX tooo....good tire....i have the same one, which model?
Mueller
May 13 2005, 04:05 PM
QUOTE (rd914 @ May 13 2005, 03:03 PM) |
Thanks. I'm gonna go with 205/50/15s. |
good choice, but just so you know, the OD of the new tires will be smallers, so better acceleration, however, the rpms will be higher while cruising on the freeway.....not a bad thing.....
TravisNeff
May 13 2005, 05:04 PM
I went with 205x55's, last set was 195x60. You might need to shop around to a tire shop that can fit a 205 on a 5.5 inch rim. I was trying to get some done on a sunday which means gas station garages and whatnot, I had to go to a few different places to get someone with the right attachments for their machine. A week later I had some other tires fitted and watched as one guy stood on the tire as the other rotated the mounting machine - tight fit!
Are you running Porsche wheels or aftermarket ones? If you are doing aftermarket you will most likely have trouble with clearance. If you have aftermarkets I would offer out 195x60 as a nice choice.
CptTripps
May 13 2005, 06:50 PM
I have 4-bolt fuchs with 205/50/15s The acceleration is pretty awesome...handeling is amazing...Speedo is WAY off.
I went with the BFG g-Force Sport. KICK_ASS tire...for $75ea at Tire Rack...Or FREE from NTB if you do it right!
mikelsr
May 13 2005, 07:04 PM
I put 205/50VR-15 Yokohama AVS ES100 (from Tire Rack) on Predinis and they did great on the AX. Now I need to get the my suspension setup correctly.
Joe Ricard
May 13 2005, 07:57 PM
Just one more thng to fog up the whole picture.
205/50-15 street tire fits really nice. not much tire crown.
Kumho Ecsta V700 R is wider and has some crown not terribly bad. Now Hoosier 205/50-15 AS04 is 3/4" wider than Kumhos Nearly as wide as a 225/45-15 Tread section will be 8.3 inches of rubber on the road.
toecutter
May 13 2005, 08:18 PM
QUOTE |
I went with the BFG g-Force Sport. KICK_ASS tire...for $75ea at Tire Rack...Or FREE from NTB if you do it right! wink.gif |
Um. Free from NTB? That sounds good to me. How is that done?
firstknight13
May 13 2005, 08:37 PM
will 205 50or55 rub cornering on the fronts??
Mueller
May 13 2005, 08:46 PM
QUOTE (firstknight13 @ May 13 2005, 07:37 PM) |
will 205 50or55 rub cornering on the fronts?? |
no rubbing on the front, in fact on the 914's, you can actually run a wider rim and tire on the front than you can in the rear
Trekkor
May 13 2005, 09:31 PM
I ran 205/50/15's on my Pedrini's for the last 8 a/x's.
Really good. They're the Yok A032r's.
I put them on my new Westerns today. Wrong backspace by 5/8-3/4 inch. It's o.k. though, got crazy rolled fenders.
Yes, the Hoosier's are a lot wider even though they call them 205's.
Got them on another set of Westerns.
KT
Trekkor
May 13 2005, 09:51 PM
I almost forgot, I took these pics this morning.
They are perfect for you. Compares 205/50/15's on Pedrini's to 165sr15 Michelin's.
KT
Trekkor
May 13 2005, 09:54 PM
Here's the side view...
Look how W-I-D-E the 205's are compared to the stock issue.
KT
echocanyons
May 13 2005, 10:10 PM
I agree 205/50 15 fits perfectly under the fenders even if you want it to sit real low
914fire
May 13 2005, 10:42 PM
hey trekkor are those peds polished ?
Trekkor
May 13 2005, 10:56 PM
Yes, you like?
KT
914fire
May 13 2005, 10:59 PM
they look fantastic what media did you use to polish them?
