JFG
Jun 23 2017, 10:40 AM
I have one wire which needs to be repaired as it has frayed/shorted right before the little cylinder connector in the plug.
What are the wires secured with? Is it just solder that i can remove, repair and replace?
McMark
Jun 23 2017, 11:19 AM
Not sure what connector your talking about.
clapeza
Jun 23 2017, 11:25 AM
If you're talking about one of the connectors in the 12 or 14 position plug, yes, the little cylinder is soldered to the wire. Getting the cylinder out is easy with a punch. Getting it back in can be a little finicky.
I had to do this when I discovered the power lead to the fuel pump was nowhere to be found in the engine compartment. A DAPO had eliminated it with the conversion to the single carb. I ran a new wire to the new pump, jacking into the factory plug on the relay board. Now I'm happily back to Djet!
IronHillRestorations
Jun 23 2017, 04:11 PM
Carefully snap the connector cover off, gently pry up one side with your fingers and it should come off.
The connectors will come right out without a hitch. A de-soldering tool (solder sucker) helps in getting the old solder connection out. If you've never soldered something before, watch some videos on how to solder. You don't want a cold solder joint.
