srreality
Jun 23 2017, 04:33 PM
My horn ring/steering wheel came to me in pieces. I've reassembled it several times but the horn blows continuously as soon as I turn the key on. It's a 1973, so does not use the horn contact button. The rubber horn button center support is new. I can't find any bare wire in the wire from the horn contact ring behind the steering wheel. The 3 "horned" attachment piece on the back of the horn ring was missing the small insulating washers, so I used rubber washers from the hardware store, but I'm not sure they are really insulated the attachment screws. What am I missing?
Click to view attachment Click to view attachment
theer
Jun 23 2017, 06:17 PM
[quote name='srreality' date='Jun 23 2017, 06:33 PM' post='2499599']
My horn ring/steering wheel came to me in pieces. I've reassembled it several times but the horn blows continuously as soon as I turn the key on. It's a 1973, so does not use the horn contact button. The rubber horn button center support is new. I can't find any bare wire in the wire from the horn contact ring behind the steering wheel. The 3 "horned" attachment piece on the back of the horn ring was missing the small insulating washers, so I used rubber washers from the hardware store, but I'm not sure they are really insulated the attachment screws. What am I missing? :confused
The horn button completes ground. The horn itself may be grounding to the body. Check that first.
Does the horn blow with the pad off and the wire disconnected (and key on) as in the first picture? If so, you are getting ground somewhere along the line.
anderssj
Jun 23 2017, 06:25 PM
I had this problem a while back--the wire to the horn pad got "pinched" when I installed the pad, creating a constant ground . . . .
wndsnd
Jun 23 2017, 06:48 PM
It is grounding somewhere. There are two wires, the live and the ground. The horn blows when the button forces a ground. The ground wire is tricky, because the wheel turns. I welded a contact to a washer beneath the nut that holds the wheel. Wheel turns, washer does not. The wire and contact need to be well insulated as to not rub when wheel is turned. Usually means you bend the connector up into the housing. And heat shrink or tape.
wndsnd
Jun 23 2017, 06:50 PM
Note mine is not stock wheel and hub, but it being grounded is same. Look for the ground.
Dave_Darling
Jun 23 2017, 10:16 PM
The three-pronged piece really really really really needs to be insulated electrically from the contact piece on the back side of the horn button. The stock insulators are tubes that the mounting screws pass through, so that there isn't even a ground path through the threads of the screws.
My guess is that you haven't insulated the three-pronged part from the contact piece. Verify that with your ohmmeter. If there is any connection, you will have to make some better isolators or just find the stock ones.
Hmmm.... I wonder if Mikey is listening?
--DD
srreality
Jun 23 2017, 11:05 PM
[quote name='theer' date='Jun 23 2017, 06:17 PM' post='2499625']
[/quote]
Nope. With the wire disconnected, it is silent.
srreality
Jun 23 2017, 11:12 PM
QUOTE(Dave_Darling @ Jun 23 2017, 10:16 PM)
--DD
Dave - - - I think you're right. The stock grommets/rubber washers are AWOL, so I need to find another way to insulate those mounting screws. Those two pieces of metal need to be "unconnected" unless the horn ring is depressed. I'll work on that.
bandjoey
Jun 23 2017, 11:25 PM
I might be off base but is your steering wheel 180' upside down? If Memory serves me the wire hole is on the right side of the wheel.
rhodyguy
Jun 24 2017, 07:53 AM
Is that electrical tape where the wire goes down the hole? Spliced? That's the longest horn wire i've ever seen.
srreality
Jun 24 2017, 11:35 AM
QUOTE(rhodyguy @ Jun 24 2017, 07:53 AM)
No - - I put it there for extra "padding" where it comes out the hole. No splice, no bare wire.
srreality
Jun 24 2017, 11:41 AM
QUOTE(bandjoey @ Jun 23 2017, 11:25 PM)
The wire from the horn contact ring comes out on the left side....or at least mine does. My horn contact ring fits, but maybe it's from another Porsche model? I think Dave_Darling has the answer.......I need to insulate the 3-horned attachment piece from the metal under it......I need grommets or sleeves on the mounting screws instead of rubber washers............
srreality
Jun 24 2017, 12:29 PM
Success! I found some small rubber tubing(sliced thin cross-wise) in my junk drawer that sufficed for a "grommet" around the mounting screws on the 3 horned attachment, plus my rubber washers........voila! No horn, except when I push the horn ring. Shade tree engineering wins again!
theer
Jun 24 2017, 07:13 PM
Nice!
malcolm2
Jun 26 2017, 07:49 PM
[quote name='Dave_Darling' date='Jun 23 2017, 11:16 PM' post='2499725']
--DD
My horn is not blowing all the time, but I am confused. What is the 3 pronged thing you speak of?
