Oliver
May 13 2005, 09:53 PM
The first time I ran out of gas and Got vapor lock.
Any one got any good ideas?
redshift
May 13 2005, 10:14 PM
Add gas, and keep your foot on the gas, to the floor, and roll it over.. should prime up, shortly.
May have someone tap on the fuel pump body with a tappy thing.. you have to burp the air back..
m
SLITS
May 13 2005, 11:10 PM
How 'bout you sucked a bunch of shit outta the tank and plugged your fuel filter?
redshift
May 13 2005, 11:53 PM
That did happen, but only in cases as bad as mine is that generally a big problem.
M
Cap'n Krusty
May 14 2005, 12:18 AM
Your car FI? Cycle the key for 2 seconds at a time until the sound in the fuel system goes away. You don't have vapor lock, you have a lack of fuel. If you have carbs, turn the key on for 15 seconds, pump the pedal once, and start it up ............ The CVap'n
