7TPorsh
Jun 28 2017, 10:49 AM
I was using lug bolts on my 2.0 Fuchs but now the new set of wheels needs a slightly longer bolt. I would rather swap out the lug bolts for screw in studs.
i believe the size is M14x1.5. I haven't really measured length but I need studs that screw in then have enough length (little more than stock) for the wheel lug nuts. The wheels use ball seat inserts.
Anyone have a good set of 16 studs? or recommend a source? thx
jmitro
Jun 28 2017, 11:11 AM
I have a set of brand new studs I was going to use. They are longer than stock (I think either 60 or 80mm long) but I want to go back to stock or at least shorter.
I can get a pic at home
dansvan
Jun 28 2017, 02:55 PM
I use the above mentioned ones from track-studs as well. Very pleased
7TPorsh
Jun 29 2017, 09:28 AM
QUOTE(stugray @ Jun 28 2017, 10:42 AM)
Thanks for the lead...these seem to be the current choice for porsche owners...Shopify store so probably run by an enthusiast....
garm
Sep 11 2019, 04:50 PM
Found this thread, and it had exactly what I was looking for. Even the link is still good!
Love 914World
Literati914
Sep 11 2019, 06:57 PM
I feel safer with the pressed in studs, here are some if you're the same:
https://swayaway.com/product-category/axles...-vw/wheelstuds/
