I've been looking around for fuel pump mounting ideas and haven't really found anything that looks like the definitive answer.
75 914. My fuel pump access door is missing. The previous owner had the fuel pump lying in the front trunk with wire nuts making the connection and then was wired to a switch and single glass fuse under the dash with the wires just twisted together. I'm guessing this was to bypass the fuel pump relay as my car has carbs.
I want to keep the pump up front under the tank. I can see the bracket where the filter is supposed to mount but it's just two ears that form a shelf...nothing to actually secure the filter.
I'm going to order the tangerine racing line to run to the engine compartment as the plastic lines crumbled as I was trying to put them back in the clips.
I'm fine with purchasing a new pump and filter....just want something that will be securely mounted, safe, and trouble free.
Pictures and links are appreciated. Thanks.
