I am working on an injected 72 914 1.7.
Tested with key on, engine not running and only one pair (2 injectors) trigger for acceleration enrichment when the throttle is opened. Is one pair all there is or is it supposed to be all four (BOTH PAIRS) ?
The car is pretty gutless coming off of the line and is doing a bit of lean backfire, even at idle. The injectors are new, all the usual checks (Fuel pressure, timing, etc have been done. Vacuum leak check (Assistant nearby with Halon Botttle ) with WD-40 and starting fluid. No leaks found.
All four injectors trigger(in pairs) in the running mode so it is not a harness issue.
I have replaced a defective leaking decel valve, and I am now considering the TPS, but it is very hard to get to on a 1.7; the Throttle body is horizontal and the TPS is under it. (Yuck!)
And where is the best Theory of Operations that described the acceleration enrichment? I have read all the wonderful PB Anders stuff. And the big blue Bosch book.
The trigger points do not play in this scenario, just the TPS and the ECU.
Anyone know how to reach PB Anders?
I have read through all his wonderful stuff and cannot find the answer in all his work or in the big blue Bosch book. General descriptions are all I find.
This car is driving me crazy!
