mskala
May 14 2005, 11:38 AM
Odyssey battery mounted. Thanks to MXMARK for
the hold-down. 15 lbs, with enough power for the
weather most of us would be driving in.
Not mounted to the tray, I already had a bottom plate
that fit over the tray and is held down by the bolt and
notch on the other side.
Just another way of making the car more left-heavy.
Qarl
May 14 2005, 02:06 PM
Yes.... I like the juice... the juice... it is GOOD!
J P Stein
May 14 2005, 07:58 PM
38 to 14 lbs. Spark is gud, but adding lightness is better
mskala
May 14 2005, 08:10 PM
The thing that gets me is that the tech guys used to come over and
practically throw themselves on my normal-sized battery. Hmm,
200lbs on a 38lb item; I guess they think my car is turning like an F16.
The channel on the outboard side is bent at this point.
MXMARK
May 15 2005, 12:24 AM
Mark, it looks good. Thanks Mark here is mine in black
ottox914
May 15 2005, 06:29 AM
J.P.- that is one smooth install- which model battery is that, and where did you source it? I want to duplicate that in my car!
bd1308
May 15 2005, 07:12 AM
that name creeps me out.....otto
d914
May 15 2005, 07:53 AM
there is an acura site that sells them for $109 for the battery and 70 for the hold down. Thats about the best I've seen..
Qarl
May 15 2005, 08:14 AM
J P Stein
May 15 2005, 08:41 AM
Karl nailed it. It's the first instance that I've found something more expensive at Summit Racing.
The aluminum strap tightens against the battery as the hold down screw tightens. The upset in the trunk floor keeps it from moving laterally.....the spot is like it was made for it
I loaded oil yesterday and it spins the motor over nicely. Today we add gas & lightem' up.
d914
May 15 2005, 10:01 AM
Damn!!!! next one I get is from there. even with the add on posts ( were included with mine) still cheaper!!!! COOOL...
Marv's3.6six
May 16 2005, 07:59 AM
Anybody used one of these for a significant amount of time?
Will it spin a 3.6?
d914
May 16 2005, 08:39 AM
I've used it to spin my race motor that was outside in 40 degrees and colder over night. Got it going with no outside help. I carry one of those emergency chargers to help with the starts...haven't used it yet...I've been pretty impressed to date. Been in car 6 months.....long term storage with occasional re starts...no problem.. no outside drain, cut off switch.
MXMARK
May 16 2005, 09:39 AM
QUOTE (Marv's3.2six @ May 16 2005, 05:59 AM) |
Anybody used one of these for a significant amount of time? Will it spin a 3.6? |
Marv, I have been using one in my 911 for about 9 months now with no problem. Let me know I have these batteries new from my work. And I should be able to get another box. I have been told that I should be using a 925 instead of the 680 in my 911 because of all of the accs. A/C, radio, cruise, windows, etc. but the 680 has worked well. My 911 turns over quicker then my big 2.5L 4 cylinder with the 680. The 680 works well in the 914 but my stereo has a drain I need a cut-off swicth. Good luck with the 3.6L Thank you Mark
