So my Creamsicle project is coming to the end. Got a new paint, good engine and tranny, and etc. The rear brake calipers are stuck so I switched those with other pair. Now it has fairly new PMB massaged calipers and was easy to adjust the clearance with no problems. But when I connected the e-brake cables to the calipers one cable is too short to attach to the arm so it tends to pull the arm with the e-brake handle in down position. I have already adjusted to max at the cable housing adjusting nuts at the firewall.
Do I have a wrong cable or can I adjust the angle of the caliper arm???
OR
I have screwed up something????
Other side is within the adjustable range to not pull at rest position.
Has anybody else encountered this before?
Thanks,
kkid
