Hello all,
A year ago I took ownership of fellow member (father) earossi's 914-6 build. Nicknamed 'the clown car' by my mother (the name stuck despite protests) I've done my best to keep up with maintenance, and I can report it's taken top awards at more than one local car show (where I was asked when Chevy made the corvette in that body style I might add..)
Big issue was an oil leak that finally got me to bite the bullet and drop the motor. Oil leak was fixed, but now a new problem. Until I dropped the motor the engine ran wonderfully and more importantly the temperature never went above 210. Flash forward to trying everything out prior to parade and suddenly we have issues! temperatures would shoot up to 240 (which was the max extent of my courage.) In a review I noticed the engine seal was out of alignment. On closer examination I realized the engine seal was cracked, split, and generally trying to escape from the engine bay. All it took really was a tear about two inches long on the driver's side.
The motor is a 3.2 from a 1988 911, complete with ECU, and I noted that when I temporarily patched the torn area (tape) the temps went right back to 210. So! Thanks to 914rubber.com (on whom I've come to depend on all things 914 seal related) I ordered a new set. I also verified I can, in fact, install the new seals with the motor still in. Brad Meyer stated it would be 'difficult.' I suspect He's being optimistic about my skills. So, any advice? Dish soap is easy, I'll be cleaning the tracks, I have the HF cudgel kits, and as you can see I've labeled the heck out of the seals to make sure I don't install them backwards or upside down. This is a learning process as this is my second Air Cooled car, and the first that could actually exceed 80 mph. Enjoy the photos!
Here we've got the driver's and passenger's sides removed. The tape was temporary, I swear it wasn't there long.. mainly because the adhesive melted off...
More gory crime scene photos of the murder of effective air cooling.
While the passenger's side seal came out in one piece, I was suspicious...this was hiding in the...cracks?
This is a comparison of the seal at the front of the motor vs. the passenger's side.
This is the passenger's seal track. I discovered sadly, just why it was easier to remove. I promise the rest of the car is in great shape! (hell hole, longitudinals, etc.)
The new seals arrived today. Yes that's sharpie, I'm not taking any chances given my ability to get it wrong
